Home > Technical (L322) > REAR WASH/WIPE |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
Mine has also blocked up, so I will have a go at unblocking it next weekend. Do you need to take the interior trim off to get access to the boot spoiler bolts?
21st Aug 2011 9:13pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
mine just popped off "RANGEISM WILL NOT BE TOLERATED"
21st Aug 2011 9:23pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
when you lift the upper part of the tail gate and look up to the metal area at the top you will see three 10mm bolt heads, left, right and centre.
22nd Aug 2011 5:18am |
I removed the spoiler and the wiper arm then confirmed the non return valve was not blocked by operating the rear screen wash. It was fine so I set about clearing the nozzles with a needle. All sorted now
22nd Aug 2011 7:11pm |
