Home > My Range Rover > 2012 Vogue TDV8 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
Your engine has either a current or historical oil cooler leak issue where the gaskets fail and allow oil into the coolant. The ensuing blackening of the header tank is the result and that’s why yours looks like it did. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
26th Apr 2024 8:00pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2761 |
Did they change the oil cooler or just the seals? 2012 TDV8 Vogue (L322) |
27th Apr 2024 10:21am |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 26 |
A correction is required as I have misread the wrong bill. That was for the transmission cooler.
27th Apr 2024 1:00pm |
Hmmm. Any oil underneath the engine in the round cross member on the trailing edge of the engine undertray? Classic symptom. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
27th Apr 2024 1:24pm |
Thanks, I will take a look. |
27th Apr 2024 1:26pm |
Finally I have it all connected and an engine start today. I ran it up for a bit and there are signs of warm air from the heater but I ran out of coolant so it's now cooling down. It never reached above a quarter on the gauge so I doubt the thermostat has opened.
5th May 2024 3:02pm |
I decided to replace the door handle cable as it was notchy and at the end of its travel. Apart from discovering plenty of dust, I've made a massive blunder.
9th May 2024 2:02pm |
]I've watched a couple of YouTube videos that show cutting the door striker but using a knife on the other side as a test, I don't think this is practical unless the blade is very bendy
10th May 2024 12:34pm |
