Home > Maintenance & Mods (L322) > Best place to buy a service kit |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 521 |
Try Advanced Factors
5th May 2024 7:52am |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 468 |
Where to buy from depends on whether you want genuine filters or not?
5th May 2024 7:54am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1782 |
Find your local indy, and use them for parts |
5th May 2024 9:19am |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1251 |
Opie? just type in your reg and you have a choice of oils and filters for your model 2018 SE SDV8 4.4 Byron Blue |
5th May 2024 9:20am |
Buellie Member Since: 28 Jan 2024 Location: Essex Posts: 145 |
Thank you both.
5th May 2024 9:23am |
PDC Member Since: 02 Oct 2018 Location: Warwickshire Posts: 75 |
+1 for Advanced Factors. Fast delivery & very helpful staff. Mention the forum & you get a discount too. 2010 RR Autobiography 5.0 SC
5th May 2024 11:21am |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 |
Plenty of S&A users on here. I've used their oils for years. Extremely knowledgeable people, very well connected in the industry, and none of the things I've lubed with S&A products have gone bang yet (from lawnmowers to light commercials if it has a hole for lube to go in, I've used S&A in it). Just done my fourth change in a year with S&A oil for my 4.4TDV8. 35K miles since last January when I bought the car, and 34.5K of those have been done on the S&A. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica. Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500 Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten! |
7th May 2024 9:44am |
No problem! Extractor makes the job very easy, you may need to do it in 2 goes as the engine has 10L in it! Although you may not get 10L out, you should definately get just over 9L! Fuel filter - On the official LR servicing schedule (as I understand it), the fuel filter is down for every 2nd service, so every 2 years or 32K miles. I would say if you're doing 8K miles per year, then every 3 years would be fine. Transfer Box - Official LR service schedule states a fluid change every 80K miles. I'd do that for sure. It needs a very specific oil, which you can get from Advanced Factors or genuine oil from a LR dealer. Engine Oil - I use S&A for all my oils - except that is for my (now gone) L322 4.4 TDV8 - I use to use Shell Helix Professional AF-L as I just wanted to put the very best in that engine. Wasn't cheap at around £100+ for 10L, but I just wanted the very best in that engine. Here's the stuff I use to put in my L322 4.4 TDV8 - https://www.shell.co.uk/fuels-oils-and-coo...5w-30.html Nothing wrong with S&A though and they use Shell base stock oils. It was just my personal choice in that car. 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) Last edited by D3Jon on 23rd May 2024 5:15pm. Edited 1 time in total |
7th May 2024 10:51am |
Many thanks again Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
7th May 2024 11:38am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
Just go with Opie Oils - can get all the parts on there including the OEM, and they are a reasonable price across the board.
7th May 2024 6:43pm |
+1 for Petronas 5000 FJ 2018 SE SDV8 4.4 Byron Blue |
8th May 2024 8:21am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
I may try Petronas next as I don't want to risk using somthing not approved by JLR 2012 TDV8 Vogue (L322) |
8th May 2024 8:36am |
Good Boy/Girl/gender Neutral person 2018 SE SDV8 4.4 Byron Blue |
8th May 2024 9:06am |
