Home > Maintenance & Mods (L322) > Best place to buy a service kit
Buellie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
I am going to service my 4.4 TDV8 myself and am looking for a place to buy a service kit from. Where is the best value vendor to buy from.
I need oil and air filters, pollen filter, fuel filter and oil is there anything else to buy? Discs and ads recently renewed all round so brakes okay.
Thanks Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #691937 5th May 2024 8:34am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Try Advanced Factors
https://www.advancedfactors.co.uk/service-...-168-c.asp 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #691939 5th May 2024 8:52am
D3Jon
Where to buy from depends on whether you want genuine filters or not?
Duckworth's spring to mind if you want genuine parts, not sure they do a 'kit', but you can order up the bits individually, you're only really going to need four filters (2 x air, 1 x pollen & 1 x oil) + the best low-saps oil you can afford (to take care of your DPF) Thumbs Up
Advanced factors are very good and there's a forum discount code you can use - AF4LRP
I also use Opie Oil a lot for my fleet and have found them to be very good, they also generally have a working discount code if you sign up with them.
Links below:
https://www.duckworthparts.co.uk/landrover...items.html
https://www.advancedfactors.co.uk/range-ro...12-7-c.asp - assuming L322?
https://www.opieoils.co.uk/
One word of advice, if you're sucking the oil out with an extractor, then you won't need a sump plug & washer, if you're dropping it from the sump, then good luck - they can be VERY tight as main dealers never remove them! I'd personally invest in an oil extractor - makes the job very easy!
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #691941 5th May 2024 8:54am
Mikey
Find your local indy, and use them for parts Thumbs Up
Post #691946 5th May 2024 10:19am
Kot
Opie? just type in your reg and you have a choice of oils and filters for your model 2018 SE SDV8 4.4 Byron Blue
Post #691947 5th May 2024 10:20am
Buellie
Thank you both.
Jon I have just taken delivery of a 9L extractor, and also have a 12v pump that I use on my Mercedes.
I have seen on here oil made by Smith and Allen is this good enough or should I go for something else? I will take a look at Opie oils.
Would you change the fuel filter very year or longer? I would have thought every 3 years or so as I am only doing around 8k miles a year in the car.
I see that Duckworths do service kits, however there is not one listed on their website on for the 4.4 TDV8.
From the service history I cannot see the diff and transfer box oil having been changed, so I would like to do this as well, any oil recommendations for those please. Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #691949 5th May 2024 10:23am
PDC
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
+1 for Advanced Factors. Fast delivery & very helpful staff. Mention the forum & you get a discount too. 2010 RR Autobiography 5.0 SC
2020 F-Pace SVR 5.0 SC
2018 RRS HSE Dynamic 3.0
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #691955 5th May 2024 12:21pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
Buellie wrote:
Thank you both.
Plenty of S&A users on here. I've used their oils for years. Extremely knowledgeable people, very well connected in the industry, and none of the things I've lubed with S&A products have gone bang yet (from lawnmowers to light commercials if it has a hole for lube to go in, I've used S&A in it).
Just done my fourth change in a year with S&A oil for my 4.4TDV8. 35K miles since last January when I bought the car, and 34.5K of those have been done on the S&A. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #692054 7th May 2024 10:44am
D3Jon
Buellie wrote:
Thank you both.
No problem! Extractor makes the job very easy, you may need to do it in 2 goes as the engine has 10L in it! Although you may not get 10L out, you should definately get just over 9L!
Fuel filter - On the official LR servicing schedule (as I understand it), the fuel filter is down for every 2nd service, so every 2 years or 32K miles. I would say if you're doing 8K miles per year, then every 3 years would be fine.
Transfer Box - Official LR service schedule states a fluid change every 80K miles. I'd do that for sure. It needs a very specific oil, which you can get from Advanced Factors or genuine oil from a LR dealer.
Engine Oil - I use S&A for all my oils - except that is for my (now gone) L322 4.4 TDV8 - I use to use Shell Helix Professional AF-L as I just wanted to put the very best in that engine. Wasn't cheap at around £100+ for 10L, but I just wanted the very best in that engine.
Here's the stuff I use to put in my L322 4.4 TDV8 - https://www.shell.co.uk/fuels-oils-and-coo...5w-30.html
Nothing wrong with S&A though and they use Shell base stock oils. It was just my personal choice in that car. 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Post #692060 7th May 2024 11:51am
Buellie
Many thanks again Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #692064 7th May 2024 12:38pm
garyRR
Just go with Opie Oils - can get all the parts on there including the OEM, and they are a reasonable price across the board.
You can also get Petronas 5000 FJ oil which has the relevant JLR approvals, and isn't just an oil which claims to meet the standards.
PartsinMotion are also a great company and very cheap and free delivery - they don't sell oil but have everything else. Febi Bilstein parts are always good value and good quality. Fuel filter wise, I use the OEM one which is Mahle. 2015 Range Rover Autobiography 4.4 SDV8
Post #692100 7th May 2024 7:43pm
Kot
Thumbs Up +1 for Petronas 5000 FJ 2018 SE SDV8 4.4 Byron Blue
Post #692129 8th May 2024 9:21am
JayGee
I may try Petronas next as I don't want to risk using somthing not approved by JLR Rolling with laughter 2012 TDV8 Vogue (L322)
Post #692130 8th May 2024 9:36am
Kot
Good Boy/Girl/gender Neutral person Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #692133 8th May 2024 10:06am
