Home > Technical (L322) > Air sus 4.4 TDV8 - normal ride height only C1A20-64
Whussain5
United Kingdom 2010 Range Rover Vogue TDV8 Buckingham Blue
Hi all
So here it goes, had a few nightmare months with our beloved Range Rover, but currently have an issue that I can’t seem to get rid off Sad the current fault is normal ride height only, on my diagnostic tool i have the error code C1A20-64 - system reservoir filling too slowly.
To resolve the issue I have replaced the desiccant for the air dryer including all seals and washers (X8R) there was a small air leak once replaced in the cap but I have sorted that and there is no signs of an air leak from the compressor. I have got underneath and sprayed the reservoir with soapy water but can’t locate a leak. The car does not drop over night or after a couple of days but we did leave it parked for 5 days (on a slight slope at my mums house) one time while we were away and the OSR had dropped a fair bit (this was the side that was lower on the slope). I have a tried to locate a leak but no luck from the reservoir and bag. So I am a little stumped as to what to try next?
In the previous weeks i had the adaptive dynamics fault which i resolved thanks to this forum by locating the wires on the front strut and locating the break and repairing.
Also we did have a faulty ride height sensor at the front which i replaced (I had initially put it on incorrectly as the sensor was giving a negative reading but I soon figured it out and put it on correctly)
Thanks to this forum I have resolved most of the issues but this is a problematic one and I could do with your advice and help so thank you to the forum members in advance you have helped loads already.
We are based in Wakefield if anyone is close by or can recommend anyone that would be appreciated
Many Thanks
Post #691704 1st May 2024 4:27pm
ballast
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
I think you're already along the right lines, i.e. air leak somewhere. A previous D3 I owned had the same fault and symptoms caused by a pin hole in the reservoir (which I found almost by accident). If the compressor is functioning correctly, then you're leaking air somewhere. I think all you can do is follow each line through from the compressor. I assume the compressor isn't running excessively? Also, one side dropping, regardless of incline, etc. could well indicate where the problem is.
Sorry it's not very definitive, I'm sure there will be others with much more specific knowledge/wisdom.
Best of luck!
Post #691707 1st May 2024 5:14pm
JayGee
Did you recalibrate after fitting the new height sensor? 2012 TDV8 Vogue (L322)
Post #691728 2nd May 2024 7:50am
Whussain5
Hi
Yes I did do a height calibration after fitting the height sensor. All the height sensors are now within operating range with no issues as far as I can tell.
Thanks to everyone who has replied so far it’s much appreciated
Post #691761 2nd May 2024 3:21pm
Giffer2018
United Kingdom 2011 Range Rover Vogue TDV8 Galway Green
Does it move to all three height settings ok, upwards and downwards?
Have you checked each airbag for leaks at each height setting?
Have you cleared the error code, does it come back?
Hope this helps -----------------------
RR Vogue 4.4 TDV8 2011 - Galway Green
Kia Sorento 2.5 CDi 2007 - Bright Silver
Post #691774 2nd May 2024 5:05pm
Whussain5
If i clear the fault code it can move up a down in all 3 positions but the code quickly comes back and then it’s stuck.
One thing i have noticed is that there seems to be a big discharge of air from the back of the car (not compressor but outside the vehicle) and then the light comes on. I only noticed this again just now as I was about to carry out another ride height calibration when stood outside the vehicle
Does anyone have any ideas as to what that discharge of air could be related to and why the error pops up shortly after?
Post #691832 3rd May 2024 3:56pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
Have you looked at the valve block ? Checked to see if that’s leaking or what about getting a rebuild kit for all valve blocks ,I was having similar issues turned out it was the front valve block seals ….kit is only £18-20 .worth a go
Post #691847 3rd May 2024 7:27pm
Whussain5
Thanks for the advice, where did you purchase the rebuild kit for the valve blocks? I’ll definitely give it a go. Thanks
Post #691859 4th May 2024 5:47am
will308f
i used the kit from ..4x4airseals.com Thumbs Up
Post #691861 4th May 2024 6:26am
Whussain5
Brilliant thank you will give it a go and report back
Post #691862 4th May 2024 9:03am
JayGee
Is the air leak at all 3 heights or only one? 2012 TDV8 Vogue (L322)
Post #691874 4th May 2024 11:07am
Whussain5
It’s stuck in normal ride height only, and if there is a leak then its slow because it can be days before any drop (if there is any)
Post #691875 4th May 2024 11:13am
JayGee
What about the big discharge of air - this is not normal as the only vent is on the pump. The air springs usual develop a leak on the fold where the rubber gets deformed the most and this can be worse at different hight settings. 2012 TDV8 Vogue (L322)
Post #691877 4th May 2024 11:23am
Whussain5
I can’t see or hear any leaks from the rear bags the front bags were replaced about 8 months ago as a pair. I’ve used the old washing up liquid solution and sprayed it and can’t see any bubbles so I’m stumped.
I’ve ordered a new compressor dryer cap from x8r this morning and the valve block recondition kit mentioned earlier in the thread this morning. I’m hoping this will resolve the issue.
Thank you all for your time to respond and offer advice it’s much appreciated
Post #691881 4th May 2024 11:58am
JayGee
Post #691888 4th May 2024 12:50pm
