Home > Technical (L322) > Air sus 4.4 TDV8 - normal ride height only C1A20-64 |
ballast Member Since: 18 Feb 2016 Location: Midlands Posts: 46 |
I think you're already along the right lines, i.e. air leak somewhere. A previous D3 I owned had the same fault and symptoms caused by a pin hole in the reservoir (which I found almost by accident). If the compressor is functioning correctly, then you're leaking air somewhere. I think all you can do is follow each line through from the compressor. I assume the compressor isn't running excessively? Also, one side dropping, regardless of incline, etc. could well indicate where the problem is.
1st May 2024 5:14pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3052 |
Did you recalibrate after fitting the new height sensor? 2012 TDV8 Vogue (L322) |
2nd May 2024 7:50am |
Whussain5 Member Since: 18 Feb 2022 Location: Wakefield Posts: 15 |
Hi
2nd May 2024 3:21pm |
Giffer2018 Member Since: 25 May 2020 Location: West Yorkshire Posts: 51 |
Does it move to all three height settings ok, upwards and downwards?
2nd May 2024 5:05pm |
If i clear the fault code it can move up a down in all 3 positions but the code quickly comes back and then it’s stuck.
3rd May 2024 3:56pm |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 289 |
Have you looked at the valve block ? Checked to see if that’s leaking or what about getting a rebuild kit for all valve blocks ,I was having similar issues turned out it was the front valve block seals ….kit is only £18-20 .worth a go 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather |
3rd May 2024 7:27pm |
Thanks for the advice, where did you purchase the rebuild kit for the valve blocks? I’ll definitely give it a go. Thanks |
4th May 2024 5:47am |
i used the kit from ..4x4airseals.com 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather |
4th May 2024 6:26am |
Brilliant thank you will give it a go and report back |
4th May 2024 9:03am |
Is the air leak at all 3 heights or only one? 2012 TDV8 Vogue (L322) |
4th May 2024 11:07am |
It’s stuck in normal ride height only, and if there is a leak then its slow because it can be days before any drop (if there is any) |
4th May 2024 11:13am |
What about the big discharge of air - this is not normal as the only vent is on the pump. The air springs usual develop a leak on the fold where the rubber gets deformed the most and this can be worse at different hight settings. 2012 TDV8 Vogue (L322) |
4th May 2024 11:23am |
I can’t see or hear any leaks from the rear bags the front bags were replaced about 8 months ago as a pair. I’ve used the old washing up liquid solution and sprayed it and can’t see any bubbles so I’m stumped.
4th May 2024 11:58am |
4th May 2024 12:50pm |
