![]() | Home > Technical (L322) > few questions - L322 4.4 TDV8 2012 Range Rover Vogue |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 868 ![]() ![]() ![]() |
This may help with the "Water fuel sensor" error
fatu Member Since: 02 Feb 2024 Location: Prague Posts: 41 ![]() ![]() ![]() |
oh thanks, this is real than. I will check fully, thought this was caused by battery level. Range Rover 2012 4.4 TDV8 - current
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
Adaptive cruise: if you don't have the distance buttons, it's not fitted. Wasn't standard on Vogue trim. Battery: The Varta G14 is a great choice. I fitted one around a year ago now and it's been absolutely great. Immediately cured my FBH problems and low battery warnings after a few minutes sat in the car with the radio on. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica. Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500 Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten! |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4323 ![]() ![]() ![]() |
Super lock is 2 presses by default.
thanks a lot, i already tweaked some settings with GAP IID, unlike the 2008 it really resets everything in the 2012 |
Water in Fuel OBD Error code P2264 https://www.obd-codes.com/p2264#google_vignette
Thank you all for amazing helps! Range Rover 2012 4.4 TDV8 - current
Did you fix the "Water in Fuel" error - how did you fix it ? |
Nope, I have iid plugged at all times and clear to continue daily bases… Range Rover 2012 4.4 TDV8 - current
see if this works - some petroleum jelly ( Vaseline ) in the connector
I saw that, should dip it all in? just a bit around outer side, or inner side. I am just not sure if I will make it worse. Range Rover 2012 4.4 TDV8 - current
Take off the connector, and push the jelly inside - not too much, and see if it helps, you cannot do any harm - it's a quick fix that some of us have used, how long it lasts I don't know |
thanks I will try that Range Rover 2012 4.4 TDV8 - current
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Don’t leave the Gap iid plugged in when not being used, it will kill your battery very quickly.
