Home > Technical (L322) > 4.4tdv8 Engine Seize |
Markyp09 Member Since: 24 Apr 2024 Location: Dorset Posts: 3 |
My FF has a seized engine 4.4tdv8, could anyone recommend an engine builder to rebuild my engine ? |
24th Apr 2024 4:19pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
24th Apr 2024 4:24pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7921 |
There's been a few people looking & I can't recall any success.
24th Apr 2024 4:52pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1745 |
DON'T use NWS |
24th Apr 2024 8:40pm |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 192 |
Hi DM
24th Apr 2024 8:59pm |
Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 70 |
As per Dolphinboy's post...do you know what caused your engine to seize? It seems very dramatic to have happened out of the blue. 2012 TDV8 Westminster in the New Forest
25th Apr 2024 11:17am |
200,000 miles, always serviced regularly, never bullied, just had oil cooler and egr done, started one day, ticking noise, drove 3 miles, seized, preliminary inspection showed white metal on the outside of a dry looking oil filter, indicating oil pump failure. Gutted, maintained regardless, ex JLR Lease car, Jackie Stewart first keeper, full spec Overfinch Autobiography, thought we had a bit better working relationship than we actually had. Upon careful consideration there is no other vehicle within £20,000 of this things value that has the build quality, ability or comfort. |
25th Apr 2024 7:37pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
I wonder if the oil pump failed because it was destroyed by bearing metal in the oil after bearings were damaged from contamination when the oil cooler was off. |
25th Apr 2024 8:41pm |
Probably no way to find that out or prove it, I’d say. |
26th Apr 2024 11:25am |
I've got a spare block rods and pistons in std size, but I fear you'll be looking for a crank too, and genuine are pretty impossible to find.
26th Apr 2024 11:39am |
I agree but perhaps worth talking to the workshop that did the oil cooler work to see what they say. |
26th Apr 2024 12:23pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3763 |
I wonder if it is worth trying Ford for engine parts?
26th Apr 2024 2:11pm |
WeiB.beer Member Since: 10 Mar 2023 Location: Cotswolds Posts: 14 |
26th Apr 2024 4:47pm |
That's a 4.4 BMW petrol engine I think. . |
26th Apr 2024 4:52pm |
