Home > Technical (L322) > 4.4tdv8 Engine Seize
Markyp09
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
My FF has a seized engine 4.4tdv8, could anyone recommend an engine builder to rebuild my engine ?
Post #691224 24th Apr 2024 4:19pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Shocked Shocked
How did that happen?
Post #691226 24th Apr 2024 4:24pm
There's been a few people looking & I can't recall any success.
This thread is a good example & interesting read.
Some more links on this one
Sorry I can't offer any more positive help Confused
Post #691229 24th Apr 2024 4:52pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
I did a lot of research into this before deciding to rebuild my own as per the thread link Alistair has posted above. One company I was impressed by was NWS Motor Services of Whitchurch. They have bearing shells, conrods & cranks manufactured specifically for themselves. Went over (once I'd rebuilt mine) and saw the owner Nathan who is a thoroughly nice bloke and knows the 448dt inside out.
Probably at the dearer end of the market, but you get what you pay for when dealing with these engines. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #691236 24th Apr 2024 6:01pm
Mikey
DON'T use NWS Shocked
Post #691241 24th Apr 2024 8:40pm
4RRS
Hi DM
In that case I'm very glad I didn't! My friend who skimmed my 448 heads knew of a company called Motorcast who NWS bought and they turned out good work apparently.....
When I was looking I balked at the 10k miles warranty, that's about 2-3 months commuting for me. Currently at 6k since I rebuilt mine just before Easter.
Have you had dealings with NWS? L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #691243 24th Apr 2024 8:59pm
Shaun_
As per Dolphinboy's post...do you know what caused your engine to seize? It seems very dramatic to have happened out of the blue. 2012 TDV8 Westminster in the New Forest
Also: Land Rover Series 3 SWB, Mercedes 280SL, Classic Mini race replica, VW Golf SV
Previously: Audi A8, RR TDV8 Vogue, Audi Allroad, VW Golf GTI Edition 30, Audi A4 Avant, A8, A4 Sport, A6, VW Golf Mk5, Bora, Golf GTI Mk3, Jetta Mk3, Passat, Jetta Mk1, Golf Mk1
Post #691265 25th Apr 2024 11:17am
Markyp09
200,000 miles, always serviced regularly, never bullied, just had oil cooler and egr done, started one day, ticking noise, drove 3 miles, seized, preliminary inspection showed white metal on the outside of a dry looking oil filter, indicating oil pump failure. Gutted, maintained regardless, ex JLR Lease car, Jackie Stewart first keeper, full spec Overfinch Autobiography, thought we had a bit better working relationship than we actually had. Upon careful consideration there is no other vehicle within £20,000 of this things value that has the build quality, ability or comfort.
Post #691291 25th Apr 2024 7:37pm
GraemeS
I wonder if the oil pump failed because it was destroyed by bearing metal in the oil after bearings were damaged from contamination when the oil cooler was off.
Post #691292 25th Apr 2024 8:41pm
Markyp09
Probably no way to find that out or prove it, I’d say.
Post #691323 26th Apr 2024 11:25am
4RRS
I've got a spare block rods and pistons in std size, but I fear you'll be looking for a crank too, and genuine are pretty impossible to find.
Incidentally I've still got a shortblock on order since December from JLR, still no update on it's availability and that's with a FRED being raised with JLR, acecpted Vin and vehicle marked as VOR. So basically I wouldn't even bother going that route. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #691326 26th Apr 2024 11:39am
GraemeS
I agree but perhaps worth talking to the workshop that did the oil cooler work to see what they say.
Post #691333 26th Apr 2024 12:23pm
Baltic Blue
I wonder if it is worth trying Ford for engine parts?
I don’t know of any Ford models that used the 4.4, but wouldn’t cost anything to ask.
Post #691341 26th Apr 2024 2:11pm
WeiB.beer
United Kingdom 2012 Range Rover Westminster TDV8 Fuji White
This might be of interest to you, just seen it in my Facebook feed.
Post #691360 26th Apr 2024 4:47pm
Dolphinboy
That's a 4.4 BMW petrol engine I think. .
Post #691361 26th Apr 2024 4:52pm
