Home > Maintenance & Mods (L405) > How open tailgate with no power? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7809 |
Not sure on the tailgate, but you should be able to use the ski hatch behind the rear arm rest to get access to the boot area if that helps..... |
14th Apr 2024 1:01pm |
planetkiller405 Member Since: 25 Oct 2023 Location: Ipswich Posts: 18 |
thanks yes I can get into the boot itself (via internal middle section as you say, thank you) and have popped the panel as mentioned to try the cable but can't get it to pop the boot lock.
14th Apr 2024 1:07pm |
Nothing in the owners manual that I can see.
14th Apr 2024 2:09pm |
Hooked up a proper car š¤£ to the RR - my 335d - and the volts are coming up to closer to 15 and this has let me close the rear window which was open and not closing with lower volts. So this is saying to me the battery(s) are fubar so I would replace these if I could get to them š¤£š¤£
14th Apr 2024 3:20pm |
