Home > Maintenance & Mods (L405) > How open tailgate with no power? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7909 |
Not sure on the tailgate, but you should be able to use the ski hatch behind the rear arm rest to get access to the boot area if that helps..... |
14th Apr 2024 1:01pm |
planetkiller405 Member Since: 25 Oct 2023 Location: Ipswich Posts: 19 |
thanks yes I can get into the boot itself (via internal middle section as you say, thank you) and have popped the panel as mentioned to try the cable but can't get it to pop the boot lock.
14th Apr 2024 1:07pm |
Nothing in the owners manual that I can see.
14th Apr 2024 2:09pm |
Hooked up a proper car 🤣 to the RR - my 335d - and the volts are coming up to closer to 15 and this has let me close the rear window which was open and not closing with lower volts. So this is saying to me the battery(s) are fubar so I would replace these if I could get to them 🤣🤣
14th Apr 2024 3:20pm |
urman Member Since: 06 Oct 2024 Location: Bratislava Posts: 4 |
I connected a Booster (PowerBank Starter). I had the highest Booster on the market with a peak current of 25000 mAh. But I couldn't start the diesel, but I was able to energize the on-board network and open the trunk. |
6th Oct 2024 4:25pm |
Good plan.
6th Oct 2024 6:18pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1339 |
Nothing like a bit of pre-emptive maintenance with these cars in particular, -don’t wait until something fails in possibly unfavourable circumstances, particularly with consumables. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
6th Oct 2024 6:59pm |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 102 |
25000mAh is not a peak current. That is a capacity of 25Ah, which is meaningless. You need a rating in Amps to know whether it will start the car. Chris. L405 - 4.4SDV8 Vogue P38 - 4.6V8 HSE Land Rover series IIA V8 |
7th Oct 2024 6:56pm |
