![]() | Home > Maintenance & Mods (L322) > Water jet stopped coming out of rear wiper L322 2011 |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Just a few suggestions:
I had this issue. Pulled off the trim and replaced the non return valve but this may not be the issue with yours. Could be blocked in the motor, a failed pump in the reservoir, blocked jets etc. Not sure if the rear is heated either. If you pull off the hose before the non return valve you can start narrowing it down. 2012 TDV8 Vogue (L322) |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Ditto,
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 697 ![]() ![]() ![]() |
It happens regularly on my 2006 TDv8. Every time so far it's been the jets blocked by debris.
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
mine has just started leaking so have got the seal to do stans mod to correct this new vehicle purchase
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 852 ![]() ![]() ![]() |
Hi Mike, in another one of your posts, you measured it using a drill bit and it was 4mm dia, not 3 - could you confirm, thx Peter |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 216 ![]() ![]() ![]() |
I used one of these on mine https://www.ebay.co.uk/itm/272848777660?mk...media=COPY |
It was definitely 4mm bore tubing, sorry I mistakenly said 3mm.
bob-lad Member Since: 12 Jun 2015 Location: Herefordshire Posts: 92 ![]() ![]() ![]() |
... and if it's not a blockage, it may be because the hose has come off and is just filling your tailgate with water.
SeldomSeenKid Member Since: 24 Jan 2024 Location: Glasgow Posts: 71 ![]() ![]() ![]() |
Would a failed non return valve manifest itself as taking ages for water to arrive at the jet and then continuing to spray after you release the stalk?
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
taking ages to get there yes. continuing to spray - not the nrv Cheers
where is the motor in the roof or the door top? Cheers James |
Top section of the tailgate, see the video below at 1 min and 15 seconds in
