Home > Maintenance & Mods (L322) > Water jet stopped coming out of rear wiper L322 2011
pcourtney
my rear wiper works fine, but the water jet nozzle is either blocked or something else is stopping the rear water wash working - I changed the fuse, no dice, and have also tried a needle in the nozzle, have tried an air blast from my compressor, but all to no avail - anything I have missed ?
Post #661271 6th Apr 2023 11:56pm
Discotigger
Just a few suggestions:
Which fuse have you checked? I believe there are 2 water pumps for the washers with separate fuses. Fuse 43 is for the rear pump. Does the pump run (can you hear it running) when you press for the rear wash? There's a non-return valve in the water pipe just before the wiper motor, accessed from under the clip-on panel in the rear upper tailgate hatch, this may have become clogged or non-functioning. If you disconnect the pipe before the valve and run the washer, see if water comes out.
Post #661293 7th Apr 2023 8:50am
JayGee
I had this issue. Pulled off the trim and replaced the non return valve but this may not be the issue with yours. Could be blocked in the motor, a failed pump in the reservoir, blocked jets etc. Not sure if the rear is heated either. If you pull off the hose before the non return valve you can start narrowing it down. 2012 TDV8 Vogue (L322)
Post #661295 7th Apr 2023 9:18am
Baltic Blue
Ditto,
It was the non return valve that was blocked in mine .
They don’t sell the valve as a separate piece at JLR so I bought one from a garden centre (3mm bore pipe) meant for plant irrigation system, but only cost pence and has lasted several years.
Mike
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #661298 7th Apr 2023 9:58am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
It happens regularly on my 2006 TDv8. Every time so far it's been the jets blocked by debris.
There's 2 jets, that should be pointing at different distances down the screen.
Careful "rodding" (lol) with a pin has always sorted it.
Try to find as large a pin as will will fit inside the holes in the brass jets.
You can use the same pin to re-align the jets if they're not pointing where they're useful.
The brass jet is a ball that is tightish fit in the plastic housing, but it can be rotated with the pin Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #661300 7th Apr 2023 10:31am
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
mine has just started leaking so have got the seal to do stans mod to correct this new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #661304 7th Apr 2023 11:40am
pcourtney
Baltic Blue wrote:
It was the non return valve that was blocked in mine . They don’t sell the valve as a separate piece at JLR so I bought one from a garden centre (3mm bore pipe) meant for plant irrigation system, but only cost pence and has lasted several years. Mike
Hi Mike, in another one of your posts, you measured it using a drill bit and it was 4mm dia, not 3 - could you confirm, thx Peter
Post #690335 9th Apr 2024 10:40pm
PeteT80
I used one of these on mine https://www.ebay.co.uk/itm/272848777660?mk...media=COPY
Post #690337 10th Apr 2024 7:23am
Baltic Blue
It was definitely 4mm bore tubing, sorry I mistakenly said 3mm.
Post #690338 10th Apr 2024 7:39am
bob-lad
... and if it's not a blockage, it may be because the hose has come off and is just filling your tailgate with water.
Is it any wonder the tail gates rot from the inside out.
Post #690400 11th Apr 2024 1:28pm
SeldomSeenKid
Scotland 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Would a failed non return valve manifest itself as taking ages for water to arrive at the jet and then continuing to spray after you release the stalk?
Thats how mine is currently behaving. ---------------------------------
2008 L322 Supercharged
2007 Porsche 987 Boxster S
2024 BMW iX3
Post #690413 11th Apr 2024 4:45pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
taking ages to get there yes. continuing to spray - not the nrv Cheers
James
Post #690424 11th Apr 2024 6:03pm
JST
Baltic Blue wrote:
Ditto,
Mike
where is the motor in the roof or the door top? Cheers
James
Post #690425 11th Apr 2024 6:05pm
pcourtney
Top section of the tailgate, see the video below at 1 min and 15 seconds in
Post #697904 12th Aug 2024 4:19pm
