![]() | Home > Maintenance & Mods (L405) > Low SAPS 5W40 synth engine oil |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1782 ![]() ![]() |
Strictly speaking, C* spec is largely irrelevant. You need an oil equivalent to STJLR.03.5005 to meet the required specs (2.7/3.0/3.6/4.4 with DPF) |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1563 ![]() ![]() ![]() |
I downloaded the C1 and C4 specifications documents directly from the ACEA website, and went through the 3 pages of specs line-by-line. It’s remarkable how little difference there is between them, most of the parameters are identical, with only a few very minor differences, and C4 is classed as “Low SAPS” therefore will not damage your DPF. I don’t give a sh*t that it doesn’t meet JLR spec, the JLR crappy spec oil is a higher risk IMHO, chosen for fuel economy and not mechanical longevity. 5W40 C4 is a more prudent choice than 5W30 C1 if you aren’t hamstrung by a JLR Warranty.
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 184 ![]() ![]() |
Thanks for the info S.L.
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 467 ![]() ![]() |
But isn't C3 mid-SAPS, so bad for blocking your DPF? EDIT --> Or is mid SAPs acceptable as well? J 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
Don’t use C2 or C3 on a DPF car! It’s fine on older L322’s etc without DPF of course.
Stick Legs Member Since: 16 Sep 2021 Location: Somerset Posts: 27 ![]() ![]() ![]() |
The Castrol Edge 5W40 C-3 meets Ford WSS-M2C917-A
@Stick Legs:
Oh I agree, and having seen that will use C-4.
This might be me, but I thought the point of your thread was that you can't easily get it (right now), unless buying $20K's worth direct from the Emirates? <<confused>> - Where's the confused emote on this forum? ![]() ![]() 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
@D3Jon:
Gotcha |
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 145 ![]() ![]() ![]() |
If there was sufficient interest would a company such as Smith & Allan or Westway not be interested in blending an oil that is 5W40 C4 spec for us? Must be easier than importing from the UAE if so.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6740 ![]() ![]() ![]() |
Reading through this thread, can I assume this is fine for my MY17 4.4 then - https://www.smithandallan.com/product/smit...e-oil-4127 Got - 2017 SDV8 Autobiography in Loire Blue
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1151 ![]() ![]() ![]() |
Yes ,but Gremlin is suggesting 5w-40C4 might actually be better. overfinch modified |
