Home > My Range Rover > My first RR a 2013 Vogue SE
Page 5 of 6 <123456>
JamboM3
Perhaps a stupid question but when you say adjust - you mean the two torx screws and adjust up/down?
Post #687225 4th Mar 2024 9:32pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
Yes, that’s correct, I lifted mine just a few mm.
But apparently there is some adjustment in the rubber bump stops attached to the bonnet? I haven’t looked at them yet.
Post #687241 5th Mar 2024 5:22am
JamboM3
Yeah I saw that also, I will take a look at the lock at the weekend - thanks Smile
Post #687294 5th Mar 2024 7:33pm
Richie N
Interesting, I have just contacted RCV for some service work, and they suggested leaving the gearbox alone unless it has issues? They said in their experience changing the oil/filter can cause issues.
I have never heard that before?
Post #687439 7th Mar 2024 10:29am
JamboM3
Oil/filter is part of the maintenance schedule for the L405 (and L322), unlike all the sealed for life nonsense that keeps being perpetuated online - so that is nonsense, quite frankly.
Post #687462 7th Mar 2024 3:45pm
Richie N
I’ve removed the oe steps in preparation for some aluminium ones.
Post #687734 10th Mar 2024 9:32pm
Richie N
Ok, I still appear to have a slow coolant leak which I’m trying to locate. In the meantime I keep an eye on the level and top up as necessary. Is this the correct coolant? There’s so much choice these days 😳
Post #688205 16th Mar 2024 11:24am
Some pictures on this thread of a common water pipe leak if you have the rear heater... Thumbs Up
https://www.fullfatrr.com/forum/topic67828.html Pete
Post #688210 16th Mar 2024 12:52pm
PLC
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Have you tried pressurising the coolant system to help locate the leak
Post #688213 16th Mar 2024 2:15pm
Richie N
Thanks gents. Mine is leaking down the back of the engine and bellhousing so unlikely to be the rear heater. I’m trying the dye method at the moment to locate the leak. Failing that pressure testing is a good call 👍
Post #688223 16th Mar 2024 4:30pm
Richie N
Today I finally got around to removing my floppy armrest. Anyone know how it comes apart?
Post #689251 28th Mar 2024 5:12pm
Richie N
I found a new armrest (OE) in Lithuania so that is on order.
In the meantime I finally fitted one side of the new steps. The brackets weren’t perfect, I ended up leaving the rear one loose, fitted and tightened step into position and then tighten the rear bracket bolts.
Post #689592 1st Apr 2024 2:02pm
Richie N
I’m not sure I prefer them over standard black, but the wife does 🤷‍♂️ in fact I prefer no steps.
Post #689593 1st Apr 2024 2:03pm
Dolphinboy
REf coolant leak, it may be EGr cooler?
Post #689602 1st Apr 2024 2:53pm
Richie N
Yes, I hope not but you could be right. I’ve booked it in with an indie for a couple of jobs and I’ve asked them to diagnose the leak. It’s used perhaps 1/2 litre in 200 miles.
Post #689736 2nd Apr 2024 12:34pm
