Home > Technical (L405) > Battery replacement 4.4 SDV8 2014
Looping111
Switzerland 2014 Range Rover Autobiography SDV8 Luxor
My SDV8 2014 has no start&stop. Have I to reset the battery after replacement or not ? I think this is just needed when a start&stop is equipped. Is there any requirement on the battery type ? Or can I buy one with same dimensions Ampers and Ah and connect ?
Post #688946 25th Mar 2024 12:29pm
mpirie
I believe you will need to tell the ECU that the battery has been replaced as the charging regime is different for new batteries.
Mike
Post #688951 25th Mar 2024 12:59pm
MrWold
England 2014 Range Rover Autobiography SDV8 Barolo Black
OK being a bit pedantic, but I think it's the BMS that's interested in whether you have a new battery or not. Nothing to do with stop/start. Ideally tell it but it will work it out for itself after a while.
Mine, same model/year non stop start, has two batteries, you may have as well.
Both batteries are AGM type. Chris
2014 FFRR 4.4 SDV8 Autobiography Barolo Black
2012 RRS SDV6 HSE Baltic Blue
and before I saw the light:
2011 Suzuki Grand Vitara SZ5
1998 Ford Mondeo V6 Ghia X
1990 Citroen BX GTi
1973 Triumph GT6
Post #689020 26th Mar 2024 8:46am
caymanblack
Dont forget that any competent garage can plug it in and tell the car its had a new battery ,it doesnt have to go to LR. overfinch modified
Post #689024 26th Mar 2024 9:59am
Looping111
I think with IID Tool I can set the new batteries. I'm not shure, my voltage actual is arround 12.2 V. After 5 minutes with ignition on it is below 12V . Maybe I have to replace them soon.
Post #689027 26th Mar 2024 10:34am
