![]() | Home > Technical (L405) > Battery replacement 4.4 SDV8 2014 |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 907 ![]() ![]() ![]() |
I believe you will need to tell the ECU that the battery has been replaced as the charging regime is different for new batteries.
MrWold Member Since: 26 Feb 2022 Location: West Sussex Posts: 135 ![]() ![]() ![]() |
OK being a bit pedantic, but I think it's the BMS that's interested in whether you have a new battery or not. Nothing to do with stop/start. Ideally tell it but it will work it out for itself after a while.
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1159 ![]() ![]() ![]() |
Dont forget that any competent garage can plug it in and tell the car its had a new battery ,it doesnt have to go to LR. overfinch modified |
Looping111 Member Since: 28 Jan 2024 Location: Zuckenriet Posts: 14 ![]() ![]() ![]() |
I think with IID Tool I can set the new batteries. I'm not shure, my voltage actual is arround 12.2 V. After 5 minutes with ignition on it is below 12V . Maybe I have to replace them soon. |
