![]() | Home > Wheels & Tyres > Which Tyres? |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 312 ![]() ![]() ![]() |
I need one new rear tyre but my supplier says I should buy two to have them identically worn.
Jordie Barrett's sock Member Since: 01 Nov 2023 Location: South West Posts: 19 ![]() ![]() ![]() |
I've heard this before. But I'm sceptical.
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1322 ![]() ![]() ![]() |
I recently changed from pirelli scorpion to Michelin Pilot Sport 4s, a complete game changer, better grip and quieter as well, thoroughly recommend. |
Stelen Member Since: 19 Jan 2022 Location: Hampshire Posts: 14 ![]() ![]() |
Generally speaking, its said that 4mm is the tread depth tolerance measurement to keep all the cogs and gears of the transmission in the right place. |
I concur ^^^^ |
Thanks gents, sounds like I’ll be fine with one new one..👍 |
Bear In mind, if rhe remaining tyre on the axle is quite worn, it might be an idea to get it replaced as well. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7884 ![]() ![]() ![]() |
What state is your spare wheel in ? (assuming full size spare) I usually throw that into the mix & put the closest pair onto the car - sometimes it means a new spare, other times not. |
Yes, that’s a good point 👍 I need to check before making a decision. |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2243 ![]() ![]() ![]() |
I used the Michelins and bout the Pirellis a few weeks ago and I have given them 3k to get used to but changing back to Michelins absolutely superb ib Wet as well ![]() |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3028 ![]() ![]() ![]() |
An all season tyre is not going to do as well in the wet as a summer tyre unless it's quite cold. If you can run 2 sets winter and summer there is no compromise. 2012 TDV8 Vogue (L322) |
At the moment Costco £792 for 4 Michelin Pilot Sport 4 255 55 R20 for 4 |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 741 ![]() ![]() |
The problem with UK winters is a proper winter tyre is still a compromise unless you live in the North/Scotland as it can be below freezing one day and in double figures a few days later. In my experience, winter tyres aren't great at 10c+, although that is on more performance orientated cars than a FF. I think a set of decent summer and all season tyres is the best way to go. That's what I've put on my wife's Golf R and I had on my 750i, but I have a winter set on the Porsche as it's the only option. The summers are back on now though and what a difference.....in a good way! I ran Scorpion Zero All Seasons on my L405 and they were fine for the type of car it is. MY23 Panamera E-Hybrid MY19 SDV8 Autobiography - Sold |
It's the dry where summers excel at most temperatures In the wet, an all season tyre should be better except when it's very warm Source - |
