Home > Wheels & Tyres > Which Tyres?
Page 6 of 8 <12345678>
dingg1
Kumhos on mine, faultless imo
Post #682463 11th Jan 2024 10:01pm
Jordie Barrett's sock
Recently bought a 2016my L405 Autobiography fitted with Churchill (formerly Jingho) Chinese 275/40/22 on the 'turbine' wheels.
Now, never had a problem with budget tyres on anything. But then I don't really partake in traffic light Grand Prix. If anything I've found cheap tyres to last longer.
Anyway, was going to replace the Churchill tyres with my brand of choice Toyo, but I think I'll wear them out first, there's nothing wrong with them. So, onto my next point, has anyone changed from 275/40/22 to 285/35/22? The wider tyres seem to be cheaper (for Toyo) and the rolling diameter seems to be near enough identical. I also feel the wider tyres might protect the wheel rim a bit more?
Any thoughts?
Post #682498 12th Jan 2024 1:09pm
JayGee
All tyres are 'OK' / 'never had a problem' until you need to stop in an emergency on a wet road.... 2012 TDV8 Vogue (L322)
Post #682510 12th Jan 2024 3:12pm
I've also done that many times as well. I've driven hundreds of thousands of miles on 'budget' tyres.
There is no massive difference between a Landsail and a Michelin except the price.
It's the tyre version of the supermarket fuel argument.
Post #682516 12th Jan 2024 4:41pm
JayGee
The tyre tests under controled conditions would not support this. 2012 TDV8 Vogue (L322)
Post #682518 12th Jan 2024 4:48pm
Right. OK.
Have you an answer to my tyre size question by any chance please?
Post #682519 12th Jan 2024 4:49pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
I wouldn't put a Pirelli anywhere near any car I own, I simply don't understand why people rate them or why Landrover recommend them.
I've had their all seasons on before and took them off right away, like driving on under inflated tyres and shockingly bad wet roadholding and braking performance. All my P38s had them and just scary rubbish, ditch magnets. 2 brand new had to be junked because the garage couldn't get them to seal to my rims due to manufacturing defects.
Zeros I had previously on my Audi went sawtooth on me, had to replace the entire set after 9000 miles. Unused spare had cracking.
Pirelli haven't produced a decent tyre since the CN36 Cinturato and the original P7s on my Fiat Mirafiori Sport.
They even have a P7 Sport bicycle tyre, talk about playing off your heretage years.
People that pay over the odds for preceived quality need looking at, you're handing over good money to numpties who are on commission.
Your money, more landfill.
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #682522 12th Jan 2024 5:06pm
JayGee
>30k on my Verde's and still 4.5mm tread on them when I checked. Never felt anything other than fully confident under a lot of conditions inc a bit of snow. Woukd never buy cheap tyres ( for any car) as have had bad experiences with them - frightening wet handling / braking , poor life to name just 2 issues. Good testing by people like Auto Bild show this time and time again. 2012 TDV8 Vogue (L322)
Post #682524 12th Jan 2024 5:15pm
JayGee
Jordie Barrett's sock wrote:
Right. OK.
What tyre size question? 2012 TDV8 Vogue (L322)
Post #682527 12th Jan 2024 5:27pm
It's up there ^^^^
Has anyone changed from 275/40/22 to 285/35/22?
Post #682531 12th Jan 2024 5:39pm
JayGee
Embarassed missed that. I always use this for size comparisons
https://tiresize.com/comparison/ 2012 TDV8 Vogue (L322)
Post #682533 12th Jan 2024 5:45pm
Yeah, I used that. Which is why I can say the rolling diameter is about the same.
I don't forsee a problem but was wondering if I've missed anything obvious.
Post #682534 12th Jan 2024 5:48pm
JayGee
They are very close and width is only +5mm on each side so unlikley to rub. Are 275/40 22 stock size? 2012 TDV8 Vogue (L322)
Post #682536 12th Jan 2024 5:53pm
Yes. That's the standard size for 22s from new on my 405.
Post #682538 12th Jan 2024 6:16pm
fisha
275/40 is stock size yes.
The 285/35 will likely fit without issue, but I fear that the lower sidewall height may be noticeable, both in terms of the ride quality (becoming harsher) and potentially the look as well. The smaller size may look like the arches aren’t filled and its baby tyres fitted.
I looked at sizes either side of the stock size and felt that going bigger does feel like it does dull the the acceleration ( based on fitting 255/60/20 tyres which are a size up from stock), and that going smaller would be harsh and I didn’t want it any harsher than existing. V8 or else ...
Post #682539 12th Jan 2024 6:17pm
