![]() | Home > For Sale & Wanted > towbar and armature |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35476 ![]() ![]() |
no pm yet david.. |
OK thanks, my key will not turn at all?
is it the correct key gary.. |
Its one owner car so I think it must be why would the owner of had any other?
i only thought because you go through loads of cars that maybe the keys got mixed up... |
Good point but these were sent by seller to me in envelope this morning so I know they "SHOULD" be the right ones.... ![]() |
the bit 'sent by seller' makes me wonder if they are the correct keys... |
@bozmandb9, david there's a pm for you.. |
Scarey you were right I was trying the wrong key. Seller gave me two I thought they were the same but they were not...... ![]() |
at least its now sorted..mine wouldn't seperate until ample loads of wd40 sorted it.. |
depends how competent mechanic you are..i gather you would have to remove the bumper first then ,with help, offer up the armature and bolt on.. |
I had my towbar off a couple of weeks ago, simple enough job.
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
I did mine yesterday. The bolts holding the bumper support on are tight so you'll need a longish bar to get good leverage, or an air tool. The rearmost mount bolts are recessed so you'll need an extension bar as well. To manage the weight of the armature, just use a trolley jack in the middle to lift it into place. This makes positioning it very easy and a one man job. I also supported the exhaust with a small bottle jack and wooden block to stop it dropping down and stressing joints further back. |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
I needed an air gun to get the four bolts undone but apart from that the whole job is very much DIY ![]() Dealer wants 2 hours but I would allow 3 for DIY just in case ![]() Andy 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack. SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone. Gone: 2014 Discovery 4 HSE Luxury Firenze Red Gone: 2006MY Java Black TD6 Autobiography Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner, |
