![]() | Home > Technical (L405) > Transmission knocking at low speed |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
The knocking could actually be an inner or outer driveshaft joint, given you only experience this when turning? 2015 Range Rover Autobiography 4.4 SDV8 |
mlambton Member Since: 30 Sep 2021 Location: Devon Posts: 68 ![]() ![]() ![]() |
Thanks Gary. The knock can be felt at the drivers left hand hip rather than an outer corner though I accept it’s very difficult to tell while driving such a well insulated vehicle. 2015 Range Rover L405 SDV8 AB Corris grey
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1292 ![]() ![]() ![]() |
I'm sure there is something on the forum that says to do a double flush on the transferbox. |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1209 ![]() ![]() ![]() |
I have the same problem, MD did a double flush on the rear diff, but no joy changed the rear diff, under warranty.
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 196 ![]() ![]() ![]() |
Mine had the same issue a few months ago. As said above transfer case oil change cured mine |
Interesting comment on lead times for booking into MD. Earliest they could book me in was a month from now! I will update once I get the MD diagnosis 2015 Range Rover L405 SDV8 AB Corris grey
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
There is an active TSB about this issue and as said above, a double flush of the transfer box and new software should fix it...
pablomont Member Since: 28 Jul 2021 Location: Liverpool Posts: 9 ![]() ![]() ![]() |
Would you know what number the active tsb by any chance, I’d love to quote it to my md 👍 |
Stick Legs Member Since: 16 Sep 2021 Location: Somerset Posts: 30 ![]() ![]() ![]() |
Changed my transfer case and diff oils and it cured it on mine.
