Home > Technical (L405) > Transmission knocking at low speed
mlambton
United Kingdom 2015 Range Rover Autobiography SDV8 Corris Grey
Over the last couple of months A knocking has developed when full lock turning slowly either left or right.
I first thought it would be the propshaft centre bearing or at worst maybe the propshaft universal joints. However my local indy suggests its actually coming from the transfer box. Not sure how he deduced this but he seemed quite certain.
I've now booked it into my MD for their assessment (im still under full approved warranty) and hopefully I dont get the usual "....well unfortunately its just wear and tear and not covered"
Does anyone have any experience of a failing transfer box (the vehicle has done 94k)? 2015 Range Rover L405 SDV8 AB Corris grey
2010 Range Rover TDV6 HSE Narra Bronze sold
2006 Discovery 3 SE green sold
Defender 90 td5 sold
Defender 90 soft top sold
Post #686977 2nd Mar 2024 5:00pm
garyRR
The knocking could actually be an inner or outer driveshaft joint, given you only experience this when turning? 2015 Range Rover Autobiography 4.4 SDV8
Post #686982 2nd Mar 2024 5:26pm
mlambton
Thanks Gary. The knock can be felt at the drivers left hand hip rather than an outer corner though I accept it’s very difficult to tell while driving such a well insulated vehicle. 2015 Range Rover L405 SDV8 AB Corris grey
Post #686994 2nd Mar 2024 6:59pm
kevinp
I'm sure there is something on the forum that says to do a double flush on the transferbox.
Post #687007 2nd Mar 2024 9:41pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I have the same problem, MD did a double flush on the rear diff, but no joy changed the rear diff, under warranty.
Which was on backorder for six weeks so a hire car as a replacement (Warranty paid)
I have been driving around with the MD tec to pinpoint the problem,
The trouble is booking it in for the work which has taken months for a time slot.
I first complained about a year ago and still not sorted out. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #687013 3rd Mar 2024 12:45am
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
Mine had the same issue a few months ago. As said above transfer case oil change cured mine Thumbs Up 2016 4.4 diesel
Post #687019 3rd Mar 2024 7:54am
mlambton
Interesting comment on lead times for booking into MD. Earliest they could book me in was a month from now! I will update once I get the MD diagnosis 2015 Range Rover L405 SDV8 AB Corris grey
Post #687083 3rd Mar 2024 7:06pm
There is an active TSB about this issue and as said above, a double flush of the transfer box and new software should fix it...
We have done loads of these... Thumbs Up
Post #687111 4th Mar 2024 12:37am
pablomont
United Kingdom 2019 Range Rover Vogue SE SDV8 Fuji White
Would you know what number the active tsb by any chance, I’d love to quote it to my md 👍
Post #688009 13th Mar 2024 6:11pm
Stick Legs
United Kingdom 2015 Range Rover Vogue SE SDV8 Causeway Grey
Changed my transfer case and diff oils and it cured it on mine.
Dead easy job to do as well if you have an oil pump.
Even I stayed clean!
Post #689320 29th Mar 2024 12:19pm
