Home > In Car Electronics (L405) > SOS limited functionality - battery replaced but not fixed
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Hi Captain_67, check your PM's re the iid tool. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #686834 29th Feb 2024 9:31pm
lambo911
United Kingdom 2016 Range Rover Autobiography SDV8 Barolo Black
Taking the trim panel off is a pain as there are two bolts at the top of the trim panel and to get to those you need to remove the center screen surround and the one on the right hand side of the steering wheel.
You then need to pull up the dash surround to finally get access to the bolts.
Then you also need to pull off the black panel on the side of the transmission tunnel as this has two prongs that hook into the the trim panel. You don't need to fully remove it, just loosen it off so you have enough space to unhook the trim panel.
None of it is hard, it is just it feels like you can easily break the fixing clips, especially on the dash surround. 2016 AB SDV8 Barolo black
2019 AB SDV8 Santorini black
Post #686868 1st Mar 2024 9:58am
Captain_67
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Thank you for the reply you have confirmed my suspicions and it looks like it’s a slow and steady job with no short cuts. I guess LR needed to make the TCU difficult to access. Did you need to have the TCU reprogrammed after replacing the battery and if so is this a main dealer job
Thanks
Post #686870 1st Mar 2024 10:24am
lambo911
I still have the error code so a trip to the dealer is needed to get it reset with an IDD 2016 AB SDV8 Barolo black
Post #686871 1st Mar 2024 10:38am
4RRS
Not sure IID can do it, I've never seen the option on mine, but SDD will do upto pre facelift MY 2017, then it's pathfinder or Topix cloud. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #686877 1st Mar 2024 11:15am
lambo911
is SDD something you can buy for a sensible price ? 2016 AB SDV8 Barolo black
Post #686880 1st Mar 2024 11:33am
4RRS
It's a £3K+ yearly subscription for the genuine item, cracked copies are available which will do the job perfectly, you will need a VCI and a laptop however. If you have a laptop maybe look at :-
https://www.ebay.co.uk/itm/375206844313 L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #686882 1st Mar 2024 11:37am
lambo911
Thanks.
Do you need one with a hard drive, or can you just load the software onto an existing laptop, like you can with BMW stuff ? 2016 AB SDV8 Barolo black
Post #686885 1st Mar 2024 11:51am
4RRS
It's simple to install the legit version which you can download for free from topix, if you don't have a topix subscription you will need to crack it, which is a little harder. Dpending how long you want to play with it, you maybe just better paying a little more and having the operating system and cracked programme pre-installed on the hard drive and then just swap it out with your laptop hard drive.
Obviously I never did any of this (ahem) as I now have a legit topix subscription.
I guess the other option is find an indie with an SDD subscription. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #686887 1st Mar 2024 12:49pm
Captain_67
Just for information
Battery replaced but U2109 fault still present
I spoke to Inschape Chester but they refused to carryout the reset of the Telemetry ECU because I had changed the battery.
I spoke with Hatfields in Shrewsbury and they said drive it for another hour and if that does not fix it book it in and they will need 2 hours to diagnose it at a cost of £377.40
Does anyone now if the ECU can be coded out as cutting the wires and throwing the module in the bin is unlikely to work either.
Whilst I understand some of this is done for security reasons I think the changing of a battery should not be deemed as a task that only a main dealer is allowed to do and even if it is there should be a small admin charge not 2 hours of labour.
Post #687164 4th Mar 2024 1:56pm
Fifth Horseman
Scotland 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Latest version of the IIDTool software has the TCU battery test function (at least when connected to a 2018 vehicle, so should be ok for earlier ones). I've not had cause to use it so can't verify it though.
Post #687170 4th Mar 2024 2:44pm
lambo911
Whilst my car was in for an MOT at the main dealer today they cleared the fault for me free of charge.
So basically, you can't just change the battery, you also need to tell the car it has a new battery before you can clear the fault. 2016 AB SDV8 Barolo black
Post #687261 5th Mar 2024 12:51pm
