![]() | Home > In Car Electronics (L405) > Volume using Bluetooth |
RogueRanger Member Since: 03 Jan 2024 Location: Kent Posts: 117 ![]() ![]() ![]() |
I think you’ll find the volume on your phone is the reason. Normally with audio equipment, you have the input device (in this case phone) at full volume and then adjust to suit on the amp.
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1464 ![]() ![]() ![]() |
I max my volume on phone, so sounds right |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 299 ![]() ![]() ![]() |
OK, set my phone to full volume and I still have to turn up the volume in the car to around the 30 plus mark (normally 10 to 12 is fine). Connect via blue tooth to my wifes Freelander and all works as it should i.e. I don't have to turn up the volume to hear it. So a bit stumped as to what it could be.
It does sound odd.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
If you go into the audio settings of the unit (on the L322 you held the audio button for 3 seconds - not sure how you do it on the Bosch system, but i'm pretty sure it's there), you can adjust the individual volume levels outputs of phone, radio, auxiliary etc. 2015 Range Rover Autobiography 4.4 SDV8 |
