Home > Technical (L405) > All I want for Christmas..... is a new Engine
Page 3 of 4 <1234>
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
So, we had all day Sunday building the engine back up. By 5PM engine was complete with the exception of the flywheel and reluctor ring as it needed to come off the engine stand to get access to the rear end.
Monday morning (well actually a 10:30 start as had to pop into work first) & fitted the reluctor ring with the JLR tool and fitted the flywheel, locked it in place with the locking tool and torqued up. Final item was front crankshaft bolt, that's proper, proper tight!
Dragged it out of the garage towards it's home. (note the JLR patented bonnet stay Laughing)
Engine went back in very smoothly, just needs a careful bit of manouvering and keeping a close eye on the r/h/s turbo actuator as it sails very close by to the diff on it's journey home.
Started to then plumb it back in whilst my buddy was underneath taking care of bellhousing, starter motor & exhaust etc.
By 5pm we had it all back together with the exception of the front slam panel and all associated parts. So, with the intercoolers dangling on their hoses and a cable tied-in-place expnsion tank, we filled the coolant (approx. 12 litres) and 11.5 liters of Castrol Edge C1 5w-30, got the jump leads on it and cranked it over...... L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #686580 27th Feb 2024 11:08am
4RRS
Here's a list of the 'special tooling' required to complete the rebuild, whilst some are probably not critical, I'd prefer to go by the book, then when it doesn't work, I can hand on heart say I've done my absolute best!
Laser 7676 TDV8 Timing tool set
JLR-310-246 F.I.P. Timing Tool
JLR-310-248 Guide Pins F.I.P.
JLR-310-247 Setting Tool F.I.P.
303-1244 Aligner Cam Cover
303-1237 Installer - CKP Sensor
303-1121 Front Seal Installer
303-1122 Front Seal Sleeve
I'll probably keep hold of all the tooling so if anyone in the future ever needs a loan of it, I'm sure we can sort something out. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #686582 27th Feb 2024 11:16am
4RRS
Oh yeah sorry, it started up just fine and sounds nice and smooth. Hopefully get it finished off in a few days as I have work committments, but once finished and the cars actaully cleaned, I'll post up some pics.
Thanks all - it's been a blast! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #686584 27th Feb 2024 11:18am
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
Wow you didn’t hang about! 😳 well done 👏🏻
Post #686592 27th Feb 2024 12:29pm
4RRS
Just to close this out, 2 thousand miles in and running perfectly!
Keeping my fingers crossed that's it's going to behave this time!
Cheers All
Mike L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #688340 18th Mar 2024 2:23pm
qwerty
2016 Range Rover Autobiography SDV8 Carpathian Grey
That is some work well done. Thumbs Up
Post #688342 18th Mar 2024 2:34pm
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
Man I wish I were able to do something like that, excellent job! Bow down
Post #688343 18th Mar 2024 2:51pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Well, hat of to you sir, that is an outstanding job Thumbs Up Thumbs Up
I have to say I like the number plates, very swish Thumbs Up
Post #688353 18th Mar 2024 4:21pm
RikPerry
I find myself in a very similar position with a 2012 L322 4.4 TDV8 .. I'm going to pull the engine to inspect what has actually failed but i might be your first " Please can i hire you tools " customer .. Pray for me
Post #691655 1st May 2024 9:04am
4RRS
If you need any info or have any queries, happy to help. If you decide to rebuild, we can sort out the tool hire. I've also a spare block, rods and pistons, but lets hope it doesn't come to that! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #691700 1st May 2024 2:47pm
4RRS
*** duplicate post ***
Post #691701 1st May 2024 2:47pm
4RRS
Just a final update - 15K in and 3 oil changes and all running perfectly, dpf is behaving and getting good distances between regens (anything from 250 to 750 miles). Think I'm finally starting to trust it again!
And here's the funny thing - the short block I've had on order from December 23, I finally got an update on, it should be avialable in the next month! Buddy at LR has found out that due to the amount of buy backs LR has had to do on the 4.4, they have commisisoned Ford to manufacture some more units, apparently they are going through final bench testing now. Question is, do I buy it as there are only a certain amount being produced, just in case....
Post #696810 24th Jul 2024 12:19pm
DrF
If it were me I would. It won't be a bad investment either way.
Post #696812 24th Jul 2024 12:23pm
4RRS
I'd done the man maths and come to the same conclusion, better to have it sitting for a rainy day. When I move on from the SDV8, I'm sure there will be a market for a genuine crated short block. The fact that the short block is not based on an exchange core is also in my favour.
You never know, you may see it in the 'For Sale' section on here! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #696813 24th Jul 2024 12:27pm
4RRS
So, it's finally arrived 10+ months after order, trouble is, do I take it or not?? Been advised that the chance of getting another one is zero, apparently a batch have been made for JLR, but all bar this one have gone direct into the JLR system to repair all the vehicles JLR had to buy back from customers as no engines were available for warranty repairs.
What's the collective thought on this?
Many thanks L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #703411 30th Oct 2024 10:40am
Page 3 of 4 <1234>
