![]() | Home > Technical (L405) > All I want for Christmas..... is a new Engine |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 289 ![]() ![]() ![]() |
So finally got around to looking at my poorly engine. Decided to pull it and see what damage has been done, hopefully as it was still running and the knock sounded like a big end as opposed to a main bearing it maybe salvageable.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Watching with bated breath, Please keep us updated. |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1458 ![]() ![]() |
For the reason that Craig mentioned earlier, I’d strip and clean it and put it back together to have peace of mind of no bits of metal lying about.
If I get a bit of time tomorrow, I'm going to pull the crank out, inlet manifolds, cams & followers etc. and give it a good wash through in the cleaner and see what it looks like. Ultimately if I need to take the heads off to be happy that's what I'll do.
Sounds like a plan. Good luck . V8 or else ... |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2642 ![]() ![]() |
You might want to see if bearing sets are available with 1 side notched to then have the caps notched. I understand they're available for the TDV6. |
That's a good idea, the ones I've managed to find so far are however as per standard design. I'll keep looking |
So, it's been a while.... some good and some bad news!
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1464 ![]() ![]() ![]() |
Wow, hat off to you sir, looking good. |
Thanks DrF, I'm kinda enjoying the project, not so much the wallet drain however! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
Just in case any unfortunate person ever treads this path again, here's a list of parts I've replaced, all as per Topix assembly guidlines. I'm sure some parts could be skipped, but I'm going by the book and hoping for a problem free future!
Have you considered fitting a sensor for an oil pressure gauge whilst easily fitted, even if you wouldn't normally have a gauge fitted?
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 363 ![]() ![]() ![]() |
Well done 4RRS 👏🏻 great work and thread 👍 |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 195 ![]() ![]() ![]() |
Brilliant thread, |
