![]() | Home > Technical (L322) > Foam seal/insulation under wheel arch?? |
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 83 ![]() ![]() ![]() |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 290 ![]() ![]() ![]() |
It fits adjacent to the still with the widest part at the bottom. I can’t remember exactly how. It’s purpose is to prevent mud & road silt from accumulating in the wheel arch, holding moisture and so causing corrosion. TDV8 4.4 2012 |
Cheers, I tried that, couldn't quite work out orientation but found a spot for it. Need to go in the other side soon so will try to carefully remove! |
TST717 Member Since: 18 Oct 2014 Location: Inverness Posts: 35 ![]() ![]() |
These often become soaked with road debris … the part number should be in the manuals provided here. If not you can get from dealer … I changed out all of these on a Volvo XC 70 I had … great piece of mind afterwards … ( I know …. Sick right !) |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1299 ![]() ![]() ![]() |
I recently renewed the crumbly ones at the rear of the bonnet and wing. They are there for a reason. |
