Home > Technical (L322) > Foam seal/insulation under wheel arch??
RovingCanary
Hello, anyone have a diagram or photo of the foam mounting areas on a 4.4 2012 under the wheel arches?
The foam seems to have been taped on, but the first I saw it was when it fell off (from the rear area of wheel arch trim, it could even have come down from wiper motor/ brake reservoir area).
Struggling to know where to refit it, but don't like to refit cars and leave parts out!
Post #685900 18th Feb 2024 10:39am
RovingCanary
Post #685901 18th Feb 2024 10:39am
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
It fits adjacent to the still with the widest part at the bottom. I can’t remember exactly how. It’s purpose is to prevent mud & road silt from accumulating in the wheel arch, holding moisture and so causing corrosion. TDV8 4.4 2012
Post #685918 18th Feb 2024 3:19pm
RovingCanary
Cheers, I tried that, couldn't quite work out orientation but found a spot for it. Need to go in the other side soon so will try to carefully remove!
Post #685946 19th Feb 2024 12:17pm
TST717
These often become soaked with road debris … the part number should be in the manuals provided here. If not you can get from dealer … I changed out all of these on a Volvo XC 70 I had … great piece of mind afterwards … ( I know …. Sick right !)
Post #686037 20th Feb 2024 9:50am
kevinp
I recently renewed the crumbly ones at the rear of the bonnet and wing. They are there for a reason. Thumbs Up
Post #686048 20th Feb 2024 11:48am
