![]() | Home > Technical (L322) > Park Assist - step by step diagnosis |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 334 ![]() ![]() |
Same topic. 2012 L322 4.4 TDV8 Autobigraphy
1986 V8 Defender 90 County ex-Swiss Army - Red everything.... My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775 (Ex LR Chief Technician) Last edited by Range Rover L322 on 8th Mar 2024 12:29am. Edited 6 times in total |
Had this issue and lost 2 brand new PAM's....
3rd time I just loosley placed the unit on the left side upside down so water couldn't drip down the wires. I suspect the water is getting in the front side somehow rather than the back as I recently had my AV system go haywire after a lot of rain. Never had any luck with used PAM's and glad I don't have to buy another new one as they have doubled in price since I last bought one. 2012 TDV8 Vogue (L322) |
I took the internal D pillar trim out today. Wet inside as per pics. Looks like I put the tailgate aperture "boot" seal back on badly when I took it off this summer to replace the parcel shelf spring clip which was broken and meant the parcel shelf used to squeak.
1986 V8 Defender 90 County ex-Swiss Army - Red everything.... My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775 (Ex LR Chief Technician) Last edited by Range Rover L322 on 15th Feb 2024 8:03pm. Edited 1 time in total |
Now it 's stopped raining I'll check the seal on mine. 2012 TDV8 Vogue (L322) |
After a few days of rain I had a look and there was water on the top black plastic unit. I also noticed mine has the rear splash plastic fitted so now it's just a case of fitting a DIY front one. 2012 TDV8 Vogue (L322) |
Decode the Jaguar Land Rover Range Rover Part Number
Excellent!. If you look up that drip will: a) be coming from the soft black padding at the bottom of the interior D-pillar trim. b) be going from the black plastic unit to where the Parking Aid Module should be located. This is very likely the water path which ![]() I have not yet identified the water ingress point - still at work with silicon. I think it might be the top corner of the Tailgate Aperture (/Boot) Seal, but not yet conclusively proven. Does anyone know if there are any holes or potential ingress points under the Roof Rack trim covers? I removed and replaced mine 4 years ago and I cant remember. 2012 L322 4.4 TDV8 AB low mileage - a peach 1986 V8 Defender 90 County ex-Swiss Army - Red everything.... My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775 (Ex LR Chief Technician) |
Found a possible leak point around the upper tailgate bump stops as water runs down the gutter and over this on the LH side when the
tailgate is raised after rain so sealed the thread with some PTFE tape 2012 TDV8 Vogue (L322) |
Part 2 of the Shower Cap mod. First pic is my first attempt. Second pic is the solution I ended up with.
1986 V8 Defender 90 County ex-Swiss Army - Red everything.... My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775 (Ex LR Chief Technician) Last edited by Range Rover L322 on 20th Feb 2024 4:09pm. Edited 1 time in total |
Great call!.... . 2012 L322 4.4 TDV8 AB low mileage - a peach 1986 V8 Defender 90 County ex-Swiss Army - Red everything.... My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775 (Ex LR Chief Technician) |
I just pushed a plastic sheet into the gap between the body and plastic grill and it seemed to stay there without any adhesive. It’s raining heavily tonight so will inspect tomorrow when it stops. 2012 TDV8 Vogue (L322) |
Water still getting in towards the rear but now just on the new plastic cover. 2012 TDV8 Vogue (L322) |
Additional - while the Park Assist Module was damp inside - it fried the reverse speaker (sits on the back of the aluminum brar on the right hand side of the boot and which emits the beeping).
Added a new tailgate seal. Problem solved. 2012 L322 4.4 TDV8 AB low mileage - a peach
