Home > Technical (L322) > Park Assist - step by step diagnosis |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 |
Same topic. 2012 L322 4.4 TDV8 Autobigraphy
13th Feb 2024 9:55pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
Had this issue and lost 2 brand new PAM's....
14th Feb 2024 7:46am |
I took the internal D pillar trim out today. Wet inside as per pics. Looks like I put the tailgate aperture "boot" seal back on badly when I took it off this summer to replace the parcel shelf spring clip which was broken and meant the parcel shelf used to squeak.
14th Feb 2024 10:16pm |
Now it 's stopped raining I'll check the seal on mine. 2012 TDV8 Vogue (L322) |
15th Feb 2024 8:59am |
16th Feb 2024 12:33pm |
Decode the Jaguar Part Number
16th Feb 2024 6:39pm |
Excellent!. If you look up that drip will: a) be coming from the soft black padding at the bottom of the interior D-pillar trim. b) be going from the black plastic unit to where the Parking Aid Module should be located. This is very likely the water path which your 2 or 3 parking modules!.. I have not yet identified the water ingress point - still at work with silicon. I think it might be the top corner of the Tailgate Aperture (/Boot) Seal, but not yet conclusively proven. Does anyone know if there are any holes or potential ingress points under the Roof Rack trim covers? I removed and replaced mine 4 years ago and I cant remember. 2012 L322 4.4 TDV8 AB low mileage - a peach 1986 V8 Defender 90 County ex-Swiss Army - Red everything.... My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775 (Ex LR Chief Technician) |
16th Feb 2024 7:09pm |
17th Feb 2024 1:08pm |
Part 2 of the Shower Cap mod. First pic is my first attempt. Second pic is the solution I ended up with.
17th Feb 2024 5:09pm |
Great call!.... . 2012 L322 4.4 TDV8 AB low mileage - a peach 1986 V8 Defender 90 County ex-Swiss Army - Red everything.... My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775 (Ex LR Chief Technician) |
17th Feb 2024 5:36pm |
I just pushed a plastic sheet into the gap between the body and plastic grill and it seemed to stay there without any adhesive. It’s raining heavily tonight so will inspect tomorrow when it stops. 2012 TDV8 Vogue (L322) |
17th Feb 2024 11:11pm |
Water still getting in towards the rear but now just on the new plastic cover. 2012 TDV8 Vogue (L322) |
18th Feb 2024 12:44pm |
Additional - while the Park Assist Module was damp inside - it fried the reverse speaker (sits on the back of the aluminum brar on the right hand side of the boot and which emits the beeping).
27th Feb 2024 8:45pm |
Added a new tailgate seal. Problem solved. 2012 L322 4.4 TDV8 AB low mileage - a peach
7th Mar 2024 9:38pm |
