![]() | Home > Technical (L322) > Supercharged Coolant Problem - Temp Gauge Dropping |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1048 ![]() ![]() |
Funny that, this happened to my S/C on Friday too, and I have LPG as well!
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
That's interesting that you have experienced the same issue as me.....
I have investigated this a bit further but still can't get to the bottom of the problem.
I've now changed the engine coolant sensor and the thermostat and yet the problem is still there......also, there are no fault codes stored in the ECU. The system has been bled properly about three times now - I'm sure there is no air trapped.
How is your vapouriser warmed?
The vaporiser is plumbed in parallel with the heater circuit - its starts on petrol and then switches to LPG at 30degC which it does fairly quickly - there are no issues with the vaporiser freezing. It does it with the AC on or off. What I can't understand is that if I switch the engine off and start it straight back up when the gauge drops everything is fine, but if I leave it running, the temp gauge stays just above the blue and the viscous fan keeps running........ Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
I would say that the way the LPG system gets its temperature reading is not correct and causing a drop across the circuit which is cleared with a restart. Possibly needs to use its own sensor and jot share the standard landrover unit instead?? |
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 222 ![]() ![]() ![]() |
I changed thermostat on my 4.2sc and now temperature gauge sits on the centre point after pointing to 10 o'clock for ages. The rubber seal on the thermostat was completely destroyed.
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
The fan cutting in seems the strange one to me?? Surely it should go off as the temperature drops. Your problem sounds electrical to me not trapped air. |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
As the OP was 4 years ago I am guessing he no longer cares or has the car! Discovery 4 HSE
YES - I did |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
going to ask the next question, what was the problem?. |
After replacing my thermostat, I have noticed a puddle under the car. I opened her up to check today to see if I had messed something up. Assuming that I had damaged something or that one of the many tools that I have lost in the engine compartment over the years had ended up damaging the radiator, but no sign of anything associated with my fumblings, but I did notice a leaking joint where two pipes are connected to the bottom of the thermostat housing by a plastic connector.
