![]() | Home > Technical (L322) > Supercharged Coolant Problem - Temp Gauge Dropping |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
All you need is the ID and thickness of teh o ring - you will get one from any engineering supplies company. |
Based on a bit of internet research, I would suggest Nitrile over Viton. Nitrile has the lower heat range (up to 120 C) but better resistance to engine coolant fluids than Viton. Close finish though, Viton will probably also do fine. Buy one of both and if the Nitrile fails, switch to the Viton would be my solution |
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 222 ![]() ![]() ![]() |
Thank you. Such a relief to find someone to discuss o-rings with. Not many takers at home for some reason. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
All done. The old o ring was completely shot: damaged from having stuck to the aluminium casting and misshapen from age and heat.
