Home > Off Topic > Cant get my 13 pin plug out |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3808 |
I can't get my bike rack of the car because the 13 pin plug won't release, I've done a search and cant find anything so I'll cast the net wide and see if anyone has had similar problems, more importantly how did they fix it and get the plug out. Geoff |
8th Feb 2024 1:53pm |
I've had the rack a few years with no problems, I think I understand what you are saying by just twisting the neck as I tend to twist the whole plug, will give it a try if it ever stops raining. Geoff |
8th Feb 2024 5:38pm |
Brute force worked. Will check alignment etc before using again. Geoff |
9th Feb 2024 12:17pm |
kevin-t Member Since: 24 Feb 2019 Location: Sheffield Posts: 41 |
Have a 13pin adaptor on my motor for the caravan which has two seven pins.
9th Feb 2024 1:37pm |
