Home > Off Topic > Cant get my 13 pin plug out
supershuttle
I can't get my bike rack of the car because the 13 pin plug won't release, I've done a search and cant find anything so I'll cast the net wide and see if anyone has had similar problems, more importantly how did they fix it and get the plug out. Geoff
Post #685093 8th Feb 2024 1:53pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Have you tried twisting the neck on the plug to unlock it? 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #685098 8th Feb 2024 3:10pm
supershuttle
I've had the rack a few years with no problems, I think I understand what you are saying by just twisting the neck as I tend to twist the whole plug, will give it a try if it ever stops raining. Geoff
Post #685109 8th Feb 2024 5:38pm
supershuttle
Brute force worked. Will check alignment etc before using again. Geoff
Post #685180 9th Feb 2024 12:17pm
kevin-t
Have a 13pin adaptor on my motor for the caravan which has two seven pins.
My adaptor got stuck recently, on site.
Some guy came over watching me use brute force to remove it!!
He offered to put some silicone grease on the fitting.. Thumbs Up Thumbs Up Thumbs Up
Worked wonders smooth as you like now.
Bought some myself, put it on all the rubbers seals around the caravan, and on the car now.
No Smelly odours. Thumbs Up Thumbs Up Thumbs Up
Works a treat.
Cheap as chips off Amazon, around 5/6 quid a tube.
Post #685185 9th Feb 2024 1:37pm
