![]() | Home > In Car Electronics (L405) > SOS limited functionality - battery replaced but not fixed |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1682 ![]() ![]() ![]() |
Did you follow the instructions in the WM?
lambo911 Member Since: 13 Jan 2022 Location: St Albans Posts: 92 ![]() ![]() ![]() |
Hi, yes I did put it into service mode which is now turned off. 2016 AB SDV8 Barolo black |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 234 ![]() ![]() |
From the workshop manual (in the wiki):
Not sure which third party diagnostic tools can do this. It's possible that with the change in voltage during charging that the unit detected then triggered it into using the back-up (non-rechargable) battery and depleting it. Check the telematics fuse, should be fuse 41 (5A) in the passenger fuse box (supplies the telematics unit) Just for clarity, what is the fault code you are reading? |
Hi, it is U2109-09
Seems like the telematics unit needs told it has a new battery. |
Thank you.
Captain_67 Member Since: 26 Feb 2024 Location: Ellesmere Posts: 14 ![]() ![]() ![]() |
I have purchase a battery for the telemetry unit.
Don't forget to reconnect the main battery after step 6
Will not on its own reset the limited functionality message, you need to run the "TCU back-up battery test" so the TCU recognises the battery has been replaced. |
Thanks Fifth
Can't comment on removing the trim, my experience with the TCU is on the 17/18MY vehicles which have it in a different place.
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 298 ![]() ![]() ![]() |
You need to remove the centre console right hand side trim as the pedal box trim clips into it and then it's a simple few bolts. I think it's made overly difficult to reach! I did the same on my L494 and pretty sure it's a similar setup. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
Thanks
Here you go, just pulled this from topix: - https://www.fullfatrr.com/gallery/albums/u...833340.pdf L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
Perfect, thanks for the information |
