![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Belt tensioner replacement |
mezo Member Since: 13 Mar 2022 Location: Milton Keynes Posts: 22 ![]() ![]() ![]() |
depends if you are sure it's the pulley that's the problem.
kokamagi Member Since: 31 May 2020 Location: Viljandi Posts: 84 ![]() ![]() ![]() |
Thank you for your answer. Mine seems to be straight and in line and I can't even determine which pulley is culprit.
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 121 ![]() ![]() ![]() |
Hello All,
Cold start still with a chirp this afternoon.
Mfcetin Member Since: 26 Jun 2023 Location: Nürnberg Posts: 68 ![]() ![]() ![]() |
I had a squealing noise which went away after changing the tensioner. I was planing to change all pullies and the belt but decided to postpone the weather has been cold and rainy. Im not sure but I think there are more noises to be addressed. Im suspecting water pump but Im not sure. Could you gents have a listen and let me know if the sound is normal or not?
I can confirm myself. Yes it is possible and I have done this, works perfectly. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2599 ![]() ![]() |
The only issue is that the tensioner hinge wears which then causes the belt to run off. |
Yeah, but mine was fairly new and with good tension, but the pulley was moving a little bit too freely. Also the upper left pulley if looking towards engine from the front of the car, was rolling quite easily and bearing felt dry by ear.
Mine's engine cover was removed on the 1st day of my ownership, primarily to not provide cover for rats but also to not trap hot air, trying to make the hoses and plastic survive longer. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
Hi guys
bump Cheers, Greg
bump Cheers, Greg
Defo get a genuine tensioner. If you can’t afford genuine idlers it’s not as critical. 2012 TDV8 Vogue (L322) |
