Home > Maintenance & Mods (L322) > 4.4 TDV8 Belt tensioner replacement
Page 2 of 5 <12345>
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
It does seem as if the crankpully is a damper pully.The wobble is only at idle.As soon as the revs is 1500-2000 it runs smoothly.I think the damper is on its way out and will need to be replaced soon.Def not a DIY job!! 2012 TDV8 Vogue SE 4.4
Post #502385 22nd Jan 2019 10:53am
Frans@Yamorna
Any suggestions where I can source the crankshaft pully,LR022805?Pretty price at JLR!! 2012 TDV8 Vogue SE 4.4
Post #502610 24th Jan 2019 9:18am
Rambles
Is there a part number for the belt please?
And is the proper name for the belt a serpentine belt?
I was trying to book my FFRR in for belt and tensioner change yesterday, and the lady dealing with the bookings in Basingstoke told me the only tensioner was on the timing chain.
Post #509971 27th Mar 2019 6:35am
She is obviously incorrect.
The belt is generally called the Auxilliary drive belt, but serpentine belt is another common name.
Sorry don’t know the Pn on them. Could dive Dan at duckworth’s a shout for the Pn and price. duckworthparts There is nothing that can't be fixed with a hammer😜😜
Post #510032 27th Mar 2019 7:36pm
DrRob
I assume you are booking it into Harwoods? You’d save a load of cash by using an independent to do it. Just had mine fitted for around £150. I’d bet Harwoods will be at least double given their hourly rate.
Where are your based? We can recommend some places for you. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #510033 27th Mar 2019 7:39pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Hi,
adding this here as this seems to be the go-to thread for tensioner / belt replacement.
I'm replacing my belt and pulleys as the belt came off this week.
A couple of things that might be helpful to others.
- removing the airboxes is necessary, but not the upright plastic air tubes, they just need unbolting so they can be pushed out the way.
- it is easier to get the tensioner bolts out / in (especially the top left one) if you remove the top right pulley first. You can then clearly see them and get a hold of them (less risk of dropping them).
- it is possible to change the belt without having to remove the fan / cowling, and no need to drain down the cooling system, but you need a bit of patience.
In order to replace the belt with fan / cowling in place you need to:
- unplug the fan connector, unclip it from the housing, and feed it out of its location into the fan blades, gently pulling it through them a bit.
- You can then pass the old belt over the fan between the blade and the housing, which will also be in front of the cable too now. Getting the new belt in the same way.
- It is necessary to remove one bolt on the aluminium coolant tube located behind the fan, bolted to the front of the engine. This is necessary regardless of how you do it. Its an 8mm bolt, and a nightmare to get to with the fan in place, but doable. You are likely to drop this bolt, so stick a nail or something to the head of it once loose to make it easier to get a hold of (don't use too much glue as you will need to remove it later). Put a bit of card up the front of the engine from below to help guide it out when you do drop it, saves trying to find where it went multiple times.
You then lever the bracket forward a bit to get the belt between the bracket and engine.
Use the nail/whatever attached to the bolt to help you get it back in and the threads started. Then you can pull it off so you can tighten it up with a socket / spanner.
Hope that helps. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #532139 25th Oct 2019 9:02pm
GraemeS
Australia
Thanks for the tips John.
Post #532142 25th Oct 2019 9:21pm
Jayk69
i hit some deep water the other night now i have a squeaky engine sounds to me like a belt pully is probably the guilty party. so if i am going to change one part i think i will order up belts pully's and tensioner do the lot in one hit.
anything anyone thinks i need to know?
i will allow a day to complete the task as there seem to be lots to remove? 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #577464 28th Dec 2020 10:46am
Jayk69
Right then!!
i have ordered x2 belts x1 tensioner and x4 Idlers pulley's after inspection i can see part of the main belt is missing (So can only presume this job has never been done!) so at 114k miles i will do the lot and hope never to have to do them again in my ownership.
as there is currently no "How to " for this complete job i will try to document and post.
look like a real pain to do but the dealer i got the car from has agreed to go halves on parts (As i want to do all the Pulley's ) and supply the labour (I will play apprentice) parts list is
LR022809
LR022953
LR025083
LR022803
LR022804
LR024791
LR025988
Will keep you updated 2012 Vogue 4.4 TDV8 - Current
Post #577780 30th Dec 2020 2:21pm
Mike220
Thanks Jayk69, keen to see how you get on as I see this job in my future probably 2011 Vogue SE Tdv8 FFRR
Post #577783 30th Dec 2020 3:07pm
kevinp
Good luck. About to do mine. Thinking of changing the water pump at the same time so I know ALL the bearings are good then. Did you go for genuine parts?
Post #577825 30th Dec 2020 8:35pm
Jayk69
No not all genuine i went for a OEM part for tensioner from Rimmer Bros as it is a big saving and has 2 year warranty and the last pully i got from Advanced Factors as it was £96 on Rimmers but £36 from AF for the same part no (Original)
some are Genuine as there was not a pattern part to replace.
If you go all genuine i think it was nearly £400 for the parts, i paid £260 i think.
I have used pattern parts before from Rimmer on my last RR and had no complaints quality was there and never regretted the decision. I know there will be folk on here who do not agree and some times you get what you pay for!! for example the tensioner is £136 for original But £55 for a pattern part. another saving was on the belts Original £44 for primary a Drayco £18 i have used Drayco before and they good never had an issue with them.
Someone posted this link https://www.advancedfactors.co.uk/auxiliar...1791-c.asp really helpful 2012 Vogue 4.4 TDV8 - Current
Post #577849 31st Dec 2020 9:56am
kevinp
Thanks for your reply mate. I might go for a genuine tensioner and pattern for the rest then.
Post #577860 31st Dec 2020 11:30am
Jayk69
After Kevinp's comment i have decided to change the water pump as well.
As there is so much to be done coupled with the fact i am not all that tall + have big fat fore arms and hands i am going to strip the front end lights, bumper, crash bar pop hose off the rad (Need and coolant service anyhow + changing the water pump) looks like i can swing all to one side and get access to everything i need without discharging the AC.
Will document and take pics as we go.
Just ordered the water pump - Thanks to Famous Four and still waiting on Rimmer Bros on a couple of back ordered items Tensioner and one of the pullies. once i have all the parts i have a day to get the work done Shocked 2012 Vogue 4.4 TDV8 - Current
Post #579289 11th Jan 2021 11:29am
kevinp
Looking forward to see how you get on mate.
Post #579302 11th Jan 2021 1:50pm
Page 2 of 5 <12345>
