Home > Technical (L322) > Whats that noise ?
David
Spain 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Whats that noise ?
On sharp bumps, like the SMALL speedbumbs we get out here im geting a knock from the front right corner. I dont think its the shocker, could it be bushes ? Ive heard they are prone to a bit of ware at the front ?
Also can anyone point me in the direction to get some service info for my local guy ? I cant get it into Land Rover for 8 weeks !!!!!!!!!!!!!!
Post #43480 24th Dec 2010 6:22pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Bushes would be my first guess. Had similar on the left on cornering. Lower arms both sides sorted it out. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #43481 24th Dec 2010 6:29pm
David
I hope its that, also it feel different when turning left than it does right !!!!!!
Sometimes i whish i was one of them people that were oblivious to car problems !!!!!
Post #43482 24th Dec 2010 6:37pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
if your around 70-90k then chances are its your lower balljoints 2004 black Vogue TD6
Post #43506 24th Dec 2010 8:51pm
dan_uk_1984
+1 depends on your roads as to how quickly they wear out.
Post #43516 24th Dec 2010 9:17pm
David
Im at 50k but out here in spainwhere its hot and dusty !!!!!
Post #43571 25th Dec 2010 12:36pm
nbunney
Yep sounds like ball joint ptoblems.
Try here:
http://www.island-4x4.co.uk/-c-144_2316.html
I'm sure if they do not ship to Spain 1 of us caould help.
Post #43580 25th Dec 2010 2:01pm
David
How can i check what the noise is !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Driveing me mad !!!!
Post #44166 1st Jan 2011 1:39pm
GKP
United Kingdom 2003 Range Rover Vogue 4.4 V8 Cairns Blue
How can you check? Jack the front of the car up and grab hold of the wheel. Look at the suspension components while you are wiggling the wheel and replace whichever part you see moving. Not sure you should be reading this bit.
Post #44177 1st Jan 2011 6:02pm
RRCanuck
Canada 2010 Range Rover Supercharged Supercharged Santorini Black
this is the nearest post I could find to address my recent problem................
A single "knock" from the front end BUT only when braking Question My brakes seem fine, nice and smooth, no shaking or anything like that. Doesn't do it every time but more frequently than not.
Any suggestions/insight would be appreciated Thumbs Up
mike
Post #68469 14th Jun 2011 5:36am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
i know this is an old post but i am having the same problem as described above. Single knock when braking not all the time but its very annoying. Did you manage to find out what this was??
Matt
Post #235908 19th Jan 2014 6:04pm
