![]() | Home > My Range Rover > My first RR a 2013 Vogue SE |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
With respect many "local garages" do not really know how to look after RR's (except the really early ones). Maybe your regular garage are not too keen because they don't understand them.
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 363 ![]() ![]() ![]() |
I get that, it’s going there as it’s 100 meters away and I don’t want to drive the car. I have a specialist not too far Dartford Transmissions but don’t want to risk driving it there. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
Filter nearly full just means it needs a decent run - a quick motorway blast should sort it out. It's usually caused by frequent short trips.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
As long as you get the issues fixed, I don't see why you wouldn't keep it if you like the car and it's what you want.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1675 ![]() ![]() ![]() |
Minor stuff, You can’t expect any complex 10y.o. vehicle to 100% be trouble-free, let alone one made by JLR |
goldeneye32 Member Since: 10 Jan 2024 Location: Hampshire Posts: 66 ![]() ![]() ![]() |
My previous car some 7 years ago was an E class Estate, within a couple of weeks of ownership it left me stranded on the motorway with a temperature gauge in the red and coolant and steam billowing from under the bonnet!
Proftinkerpot Member Since: 23 Dec 2022 Location: County Antrim Posts: 194 ![]() ![]() ![]() |
Hopefully the coolant leak is no more than a hose or plastic housing that can be easily replaced. As others have said, any 10 year old vehicle can have issues but these are complex machines with wiring looms and ecu modules like a 747. Expect to spend a bit on maintenance and enjoy ownership. They are unlike anything else. |
Thanks gents, that’s reassuring and in line with my own thoughts. The only issue with driving it to the dealer is it’s a 30 mile drive round the m25 and I don’t want to get caught in traffic. And if it’s the cooler on top of the engine it could get water in the oil?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
Agree with what's said above... All simple fixes I hope sir |
Thanks. I don’t want to risk running the car for long. So I think I’ll get my local garage to strip the intake and see where the coolant is coming from.. |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
Just be aware that if you get any work done without the supplying dealer authorising it (in a provable written way, preferably) you forfeit any right you have to expect them to resolve a related issue under warranty/statutory protection. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Richie, have you spoken to the seller yet? Asked what they suggest? It’s their responsibility to fix it so, I’d expect them to collect it! If not, it’ll be their decision whether to drive it to them or not… Save any corespondent you have, even emails sir… 👍 |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 189 ![]() ![]() ![]() |
I have a 2012 and the list of issues when I bought it privately were quite long. None were catastrophic but all need attention at different levels of urgency. Its to be expected and I knew this when I bought mine as I had the same issue with the Discovery.
Yep ![]() |
