Home > Maintenance & Mods (L322) > air suspension inactive !!!! |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 |
I just popped down the local shop and all was fine but when I gt back in the ffrr air suspension inactive come up on the dash and the suspension ride height is on standard but the hard button loght is on coonstant I have tried altering the vehicle height but nothing happened then suddenly the front lifted on its own and leveled out the carI then went onto the touch screen and looked on 4x4 info and its showing my rear drivers side is low and a small red segment is flashing !!!! i then parked my rear drivers wheel on the krb to see if it shows it being higher than the rest on screen but it shoows the same (no movement ) Could this be a sensor ?? if so where is it situated and how much are they, or is it worse than that ????????? has anyone had this problem
12th Jun 2011 12:39pm |
Battery volts low |
12th Jun 2011 1:45pm |
all sorted !!! i went over a speed hump and everything went to normal so thinking its the sensor .. |
13th Jun 2011 3:03pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35126 |
must put that in the wiki...''air suspension inactive'', solution ,drive over speed bump to rectify.. |
13th Jun 2011 3:07pm |
i think there's only one speed bump in the 'isle of man'....must google to get speed bump specifications... |
13th Jun 2011 3:22pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2938 |
I've got the same problem, except no lights on the height switch. Hoping its the battery? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
15th Jun 2011 11:37pm |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2031 |
Noddy, had that on my TD6 and it needed a re-set |
15th Jun 2011 11:52pm |
A 're-set' for the EAS is the same as a 're-gas' for the AC: w/o having located the source of the problem, it's a stop gap measure at best. The software running your EAS is not Windows and a 're-boot' will not fix it.
16th Jun 2011 7:44am |
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 |
Bought my first 02/03 range rover last Sunday and have exactly the same problem.. found this thread so I'll take the speed bump advice onboard.
17th Jun 2011 9:37pm |
How do you reset them? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
23rd Jun 2011 10:45am |
any answer |
25th May 2012 2:40pm |
Reset=clear fault. Didn't you buy a Hawkeye, Gary?
25th May 2012 2:52pm |
no |
25th May 2012 3:34pm |
If you want to take a quick jaunt down in this direction, I can show you well the IIDTool works.
25th May 2012 4:11pm |
