Home > Maintenance & Mods (L322) > air suspension inactive !!!!
simonmanx
Isle Of Man 2005 Range Rover Vogue SE Td6 Java Black
I just popped down the local shop and all was fine but when I gt back in the ffrr air suspension inactive come up on the dash and the suspension ride height is on standard but the hard button loght is on coonstant I have tried altering the vehicle height but nothing happened then suddenly the front lifted on its own and leveled out the carI then went onto the touch screen and looked on 4x4 info and its showing my rear drivers side is low and a small red segment is flashing !!!! i then parked my rear drivers wheel on the krb to see if it shows it being higher than the rest on screen but it shoows the same (no movement ) Could this be a sensor ?? if so where is it situated and how much are they, or is it worse than that ????????? has anyone had this problem
rgds Simon
Post #68252 12th Jun 2011 12:39pm
Battery volts low
Post #68257 12th Jun 2011 1:45pm
simonmanx
all sorted !!! i went over a speed hump and everything went to normal so thinking its the sensor ..
Post #68401 13th Jun 2011 3:03pm
must put that in the wiki...''air suspension inactive'', solution ,drive over speed bump to rectify.. Laughing
Post #68402 13th Jun 2011 3:07pm
What is the optimum speed when traversing the speed bumps?
Also does the size of the speed bumps make for better results?
Post #68404 13th Jun 2011 3:11pm
i think there's only one speed bump in the 'isle of man'....must google to get speed bump specifications...
Post #68407 13th Jun 2011 3:22pm
Andy
I've got the same problem, except no lights on the height switch. Hoping its the battery? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #68725 15th Jun 2011 11:37pm
nbunney
Noddy, had that on my TD6 and it needed a re-set Thumbs Up
Post #68727 15th Jun 2011 11:52pm
SteveMFr
Site Sponsor
A 're-set' for the EAS is the same as a 're-gas' for the AC: w/o having located the source of the problem, it's a stop gap measure at best. The software running your EAS is not Windows and a 're-boot' will not fix it. Razz
Simon, there are numerous possible causes for your prob - from a sensor malfunction to an improperly operating valve. Having the fault read is a good way to start properly rectifying the problem.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #68734 16th Jun 2011 7:44am
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
Bought my first 02/03 range rover last Sunday and have exactly the same problem.. found this thread so I'll take the speed bump advice onboard.
Many thanks!
Post #69088 17th Jun 2011 9:37pm
Andy
How do you reset them? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #69719 23rd Jun 2011 10:45am
any answer
Post #123625 25th May 2012 2:40pm
SteveMFr
Site Sponsor
Reset=clear fault. Didn't you buy a Hawkeye, Gary?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #123629 25th May 2012 2:52pm
no Big Cry
Post #123635 25th May 2012 3:34pm
SteveMFr
Site Sponsor
If you want to take a quick jaunt down in this direction, I can show you well the IIDTool works. Whistle
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #123641 25th May 2012 4:11pm
