Home > Maintenance & Mods (L322) > 4.4 tdV8 turbo oil drain mod.
Page 15 of 15 <123 ... 131415
DrRob
Every day is a school day Bow down Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #676059 21st Oct 2023 4:16pm
JayGee
Just checked mine and it looked OK but was slightly off centre. Could be that with age the rubber cap hardens and doesn't seal fully. Also oil filters differ in their design with some having flat bottoms and others having a raised flange so these may press on the spring differently?
 2012 TDV8 Vogue (L322)
Post #676121 22nd Oct 2023 11:27am
InlovewithRR
United Kingdom 2012 Range Rover HSE 4.4 V8 Bonatti Grey
Hi all,
Just had checked my car. Oil filter is good, oild pressure is 1.5bar at hot idle.
Scavanger pump is new. Still exhaust is full of oil and smokes when hit on gas.
I dont believe in oil drain mod as from factoey it didnt smoke.
Any more ideas?
Post #678602 23rd Nov 2023 5:43pm
GraemeS
Australia
Twin drain was factory-fitted to the L405 4.4 from around mid 2014.
Post #678608 23rd Nov 2023 7:38pm
InlovewithRR
Finally sorted. Anybody wants to guess what wass the issue?
Post #678862 27th Nov 2023 6:15pm
kevinp
Another loose spring valve?
Post #678869 27th Nov 2023 7:45pm
InlovewithRR
Wrong oil Smile It appears there was 5w50 instead of 5w30
Post #679001 29th Nov 2023 2:41pm
JayGee
Thumbs Up 2012 TDV8 Vogue (L322)
Post #679014 29th Nov 2023 3:35pm
tooomek@icloud.com
Can someone explain how to fix vacu pump?
Post #683674 23rd Jan 2024 5:21pm
Baltic Blue
j
Just remove the black cap from the extraction tube and push on the syphon tube.
Post #683687 23rd Jan 2024 6:14pm
tooomek@icloud.com
This is not about fixing pump 😀😀😀😀
Post #683688 23rd Jan 2024 6:16pm
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
https://www.fullfatrr.com/forum/topic68176.html
Post #683758 24th Jan 2024 10:19am
