Home > Maintenance & Mods (L322) > Retro fitting Paddle Shift to early L322 |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 |
An excellent mod. Well done that man.
12th Jun 2011 4:17pm |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 |
where did you get your paddels from and how much ? |
12th Jun 2011 4:23pm |
Tim Fry Land Rovers Cheltenham
12th Jun 2011 6:27pm |
Thanks Jonno
12th Jun 2011 6:35pm |
TFL 01242 516028 Rob or Ben 5.0 supercharged autobiography
12th Jun 2011 6:39pm |
Thank You |
12th Jun 2011 6:42pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
odd they are that price at all land rover dealers
12th Jun 2011 8:19pm |
I did the wireless method using a maplin 2 channel gizmo.
12th Jun 2011 9:40pm |
thanks jonno ....ive allready got the paddles in and powered up ive also tested them now all i got to do is the wireless bit ....hopefully ill be doing it tomorrow "RANGEISM WILL NOT BE TOLERATED"
13th Jun 2011 12:15am |
is common the earth and nc the grey or blue wire? also do you just run a 12volt live to the battery terminals or leave the battery in situ if im honest im a bit lost with this bit. "RANGEISM WILL NOT BE TOLERATED" www.futuresecurityservices.co.uk Pretlove says , '' I want my car back " |
13th Jun 2011 9:44am |
this is what i brought from maplins
13th Jun 2011 11:30am |
Common is earth
13th Jun 2011 5:40pm |
thanks jonno one more question with the reciever can you tell me what wires go where as im not seeing anything for earth "RANGEISM WILL NOT BE TOLERATED"
13th Jun 2011 6:10pm |
Join the two earths from the tx to the single black earth wire from the paddles.Grey wire from the paddles to grey on the tx, blue wire from the paddles to blue wire on the tx . Now there's only a red wire on the paddles left over. The red wire powers the leds on the paddles. You don't need to connect this to make the paddles function but if you want them to look pretty in the dark you need to connect it to a positive feed in the steering wheel, the black earth wire will also need connecting to an earth on the steering wheel I didn't bother to do this. Confused......You'll get there. Jonno 5.0 supercharged autobiography Gone-4.4 Vogue Lpg now unmapped 4.6 HSET Turbo Lpg mapped Gone-Defender 90 200tdi Gone - 3.9 Sprintex supercharged LPG Gone - 3.9 Vogue LPG Last edited by Jonno on 13th Jun 2011 8:03pm. Edited 1 time in total |
13th Jun 2011 7:49pm |
