Home > Maintenance & Mods (L322) > Retro fitting Paddle Shift to early L322
Page 4 of 14 <123 45 ... 121314>
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
An excellent mod. Well done that man.
So good that I actually fitted it today at a total cost of £81.00.........a bargain me thinks! Smile 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #68271 12th Jun 2011 5:17pm
oodathort
where did you get your paddels from and how much ?
Post #68274 12th Jun 2011 5:23pm
Jonno
Tim Fry Land Rovers Cheltenham
Part numbers for the paddleshifts part no:
LR 023033
LR 023034
the pair cost me £46.00 inc vat 5.0 supercharged autobiography
Post #68295 12th Jun 2011 7:27pm
oodathort
Thanks Jonno
Do you have any contact details for him
Post #68297 12th Jun 2011 7:35pm
Jonno
TFL 01242 516028 Rob or Ben 5.0 supercharged autobiography
Post #68299 12th Jun 2011 7:39pm
oodathort
Thank You
Post #68300 12th Jun 2011 7:42pm
pretlove
odd they are that price at all land rover dealers Thumbs Up
check this thread out
http://www.fullfatrr.com/forum/topic1922-75.html
@jonno did you use the wireless method? to get the wires through the wheel "RANGEISM WILL NOT BE TOLERATED"
Post #68325 12th Jun 2011 9:19pm
Jonno
I did the wireless method using a maplin 2 channel gizmo.
Changing the paddle board is a bit of a nightmare and I gave up building a bridge as Matt sugested.(too small for this old man to see!)
It's far easier to connect a short piece of wire from the blue (or grey wire) to the corner of the button and just unsolder the 2 small resistors.
On the back of the TX as you turn it over:
left button
Left solder point = common
Right solder point = NC
Right button
Top left solder point =common
Bottom right solder point = NC
This info will make sense when you've got the bits
Apart from that a very satisfying mod all thanks to Matt! 5.0 supercharged autobiography
Post #68339 12th Jun 2011 10:40pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
thanks guys for all the great comments but i have to say a massive thanks to daveo as he is the one that got me a pair of paddles to start the project off, and thanks Jonno for doing the write up on the soldering points... this is the bit i forgot to photograph and video....doh!!
Matt
Post #68340 12th Jun 2011 11:07pm
pretlove
thanks jonno ....ive allready got the paddles in and powered up ive also tested them now all i got to do is the wireless bit ....hopefully ill be doing it tomorrow Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #68350 13th Jun 2011 1:15am
pretlove
left button
Right button
is common the earth and nc the grey or blue wire?
also do you just run a 12volt live to the battery terminals or leave the battery in situ Shocked
if im honest im a bit lost with this bit. "RANGEISM WILL NOT BE TOLERATED"
Post #68365 13th Jun 2011 10:44am
pretlove
this is what i brought from maplins
and this is what the remote looks like from the inside
if anyone could be so kind as to edit this image to show stupid me where the wires go and stuff id be very gratefull Bow down Bow down "RANGEISM WILL NOT BE TOLERATED"
Post #68381 13th Jun 2011 12:30pm
Jonno
Common is earth
blue to nc and grey to other nc
Rotate your tx 90 degs clockwise and the left solder point on the back of the left button is your first earth and so on.
When you've soldered the wires on if you touch the blue and earth together (or the grey and earth) the led on the tx board will light up - job's a good one.
I have left the battery in situ at the moment. Make sure you insulate the terminals with tape though.
And don't forget to set the reciever to "pulse" or it just won't work!
Jonno 5.0 supercharged autobiography
Post #68422 13th Jun 2011 6:40pm
pretlove
thanks jonno one more question with the reciever can you tell me what wires go where as im not seeing anything for earth "RANGEISM WILL NOT BE TOLERATED"
Post #68424 13th Jun 2011 7:10pm
Jonno
Join the two earths from the tx to the single black earth wire from the paddles.Grey wire from the paddles to grey on the tx, blue wire from the paddles to blue wire on the tx .
Now there's only a red wire on the paddles left over. The red wire powers the leds on the paddles. You don't need to connect this to make the paddles function but if you want them to look pretty in the dark you need to connect it to a positive feed in the steering wheel, the black earth wire will also need connecting to an earth on the steering wheel I didn't bother to do this.
Confused......You'll get there.
Post #68434 13th Jun 2011 8:49pm
