Home > Technical (L322) > Whistling noise when turning left |
landy95 Member Since: 04 Aug 2021 Location: Hall Green, West Midlands Posts: 79 |
My blower fan makes a slight squeel when I make a right turn, guessing the bearings are wearing. Could it be the same on yours ?? Also own a 1976 Land Rover 101 3.5 V8.
17th Jan 2024 9:32pm |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 |
Yes that’s a possibility, it’s certainly the right sort of noise. I’ll try with the fan off later and see if that makes any difference, thanks. 5.0 S/C Autobiography - now gone to pastures new.... |
18th Jan 2024 9:30am |
Full marks landy95 I tried it this morning with the fan switched off and no noise! Thanks for that, at least it's nothing major, and nothing which a bit more radio volume won't cure!! 5.0 S/C Autobiography - now gone to pastures new.... |
18th Jan 2024 1:57pm |
GRANGEROVER Member Since: 10 Feb 2022 Location: Bremen Posts: 34 |
After my fan started squeezing it took a month for it to stop working... |
18th Jan 2024 7:11pm |
I purchased a complete set of wheel bearings 2 years ago when it first started, thinking it must be the ns front. I turned the blower off one day and it was silent. The fan is still working just a bit squeaky on right hand bends. And I have a full set of wheel bearings should the need arise to replace them. I'm glad you found the issue. Also own a 1976 Land Rover 101 3.5 V8. Previously owned 1991 Range Rover Vogue 3.9 V8. |
19th Jan 2024 10:54pm |
