Home > Maintenance & Mods (L322) > Brake Line Repair
bwelton
United Kingdom 2012 Range Rover Vogue SE TDV8 Zermatt Silver
Brake Line Repair
I’ve got a section of corrosion on the brake lines by the fixing on the middle of the underside run. Has anybody else found this area susceptible to corrosion and have you cut and replaced that section only with couplers ?
I know they are steel brake lines so I guess more susceptible to corrosion than a copper alloy. Any advice on repair with with who ? I’m in the Milton Keynes area.
Thx -------------------------------------
MY 2012 4.4 TDV8
Post #605087 29th Aug 2021 6:09am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
They can be done either way, full pipe or joined with couplers. If your reasonably handy with the spanner’s they are not to difficult to do, a brake pipe flaring tool is available from Halfords or similar as is the cunifer (copper pipe). You would do the job for circa 50 quid doing it yourself. You can get a cheap flaring tool and pipe cutter for around £25. Garage prices you would need to add a couple of hours labour at least and the dreaded VAT Big Cry
And yes they are susceptible to corrosion, we loads do of them.
Post #605090 29th Aug 2021 6:39am
bwelton
Thanks for the advice Dave, I don’t think I’ll do them myself, but will look for a garage in the area
Does anybody have any recommendations for the Milton Keyes area for this sort of work ? -------------------------------------
MY 2012 4.4 TDV8
Post #605091 29th Aug 2021 6:48am
mjdronfield
My garage charged me £300 ish I think to replace mine in January, though one had burst….
Get it sorted, mine cost a further £300 odd as it stuffed the master cylinder too…..
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #605105 29th Aug 2021 12:01pm
Re: Brake Line Repair
Thx
There are two front to rear brake pipe joiners behind the NSF wheelarch splash shield sir... If asking a garage to change them, ask them to replace the two flexi's on the rear wishbones too as they rot like pigs as well! Thumbs Up
Post #605141 30th Aug 2021 1:09am
bwelton
Can anybody point me to a source for Repair Labour Hours for Jobs ? eg the replacement of the Front to Back Brake Lines of the L322 2012.
The small but well-known Repair Garage in Milton Keynes quoted and charged 3.5 hrs labour to replace both of the Corroded OEM Brake Lines in the photos from this thread. Now last weekend I did an emergency break and burst a brake line. On inspection it was found that the garage had only replaced one of the two corroded lines in the photo, even though they charged and stated at the time that both corroded break lines are to be replaced with Copper Lines. The photo was taken actually taken on the ramp at the repair garage.
They asked me to bring the car back and now say they need to charge again to replace the original OEM corroded brake line (shown in the original photo) that seemingly had not been replaced. Even though they already charged and stated at the time that it was replaced, but now are denying that the 3.5 hours charged was for both the corroded lines and saying the 3.5hrs recorded on their system job sheet says, ‘brake line repair’. They also say the mechanic has since left the company, so I must understand that. I thought I had contracted and paid the company, rather that the employee of the company. -------------------------------------
MY 2012 4.4 TDV8
Post #682998 17th Jan 2024 2:23pm
mjdronfield
See below. Labour to replace flexi pipes was £67.50, rear brake lines, £150, all plus VAT.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #683010 17th Jan 2024 4:05pm
Dolphinboy
@ MJDronfield
Can still read your address and VIN under the black marker Mr. Green
Post #683019 17th Jan 2024 4:57pm
mjdronfield
Rolling with laughter Ah, I edited it on the iPad….don’t live there now, but will see if I can amend.
Thanks
Mark
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #683020 17th Jan 2024 5:04pm
bwelton
Many thanks for the comments.
Now I’ve found the 1 brake line the garage did change is like a snake waving down the underside and not clipped. Is this normal or reasonable for a garage Brake Line repair ?
MY 2012 4.4 TDV8
Post #683095 18th Jan 2024 3:45pm
