![]() | Home > Maintenance & Mods (L322) > Brake Line Repair |
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 137 ![]() ![]() ![]() |
I’ve got a section of corrosion on the brake lines by the fixing on the middle of the underside run. Has anybody else found this area susceptible to corrosion and have you cut and replaced that section only with couplers ?
Thanks for the advice Dave, I don’t think I’ll do them myself, but will look for a garage in the area
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7860 ![]() ![]() ![]() |
My garage charged me £300 ish I think to replace mine in January, though one had burst….
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16311 ![]() ![]() ![]() |
There are two front to rear brake pipe joiners behind the NSF wheelarch splash shield sir... If asking a garage to change them, ask them to replace the two flexi's on the rear wishbones too as they rot like pigs as well! ![]() |
Can anybody point me to a source for Repair Labour Hours for Jobs ? eg the replacement of the Front to Back Brake Lines of the L322 2012.
See below. Labour to replace flexi pipes was £67.50, rear brake lines, £150, all plus VAT.
@ MJDronfield
Many thanks for the comments.
