![]() | Home > Maintenance & Mods (L322) > Has anyone tried these LED bulbs? |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
Interesting, was looking to do same as you after sorting out a friends daughter car out after she had a little mishap (ok she ran into something and smashed lights, bumper and front wing cheaper for her if I fix it with second hand parts) the S/H lights had led bulbs with the fan (normal lights on this car have H7 main beam and dip) and light output from the led bulbs was far superior hence my interest, if your front fogs are same as mine doubt they will fit but you can but try. Hope you enjoyed your chinese ( like the smell of some of it, cant stand the taste myself) Thanks for coming back with your report. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Mine in my 322 high beam were twice as bright as the halogens they replaced! Try some with the aluminium cooling ropes on |
Thank you Cam-Tech-Craig, I will seek out those, its the high beam I was interested in, replaced the hid bulbs with some 6K ones must have been 4.5k before and they are better, its a nice white light now not yellow ish as before. |
pjw888 Member Since: 04 May 2023 Location: Dumfries Posts: 30 ![]() ![]() ![]() |
Hi all, not related directly to this post but I'm trying to get confirmation on upgrading dipped beam to LED in my 2011 FFRR. I see things about just main beam upgrades but find the headlights not the best in darkness. I read some posts which state it cannot be done due to voltage changes or to remove the ballast units and associated wiring. I don't want to make any significant changes. I have seen some DS3 Led's and these are quoted as being a complete plug and play fitment.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 ![]() ![]() ![]() |
Plug and play mate…
Thanks for all your advice, I'll give these a go. |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 544 ![]() ![]() ![]() |
I've just fitted the Bevinsee LED's to both dip/main and main beams on my 2011 MY L322. To be honest the dip beam isn't really any different in output to the HID's, but it matches the main beam in colour so it was worthwhile doing. The main beams however, blimey what a difference, well worth it. Drives:
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4311 ![]() ![]() ![]() |
As above, fit Bevinsee LEDs to both bulbs per side all in one go. Huge difference overall to light and appearance. I've also done the full interior, side repeat indicators, reversing ones and the rear number plate. Refreshes the entire car from ![]() ![]() 4th post down has my links in there amongst all the other "stuff" ![]() https://www.fullfatrr.com/forum/topic44115-75.html ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
Even in the image you can see a little more glare from the LED........... |
That's just because it's brighter. The beam patern is very clear and well defined. If I get the chance I'll put one of the old bulbs back in and point it at a wall and take a picture of that. 2012 TDV8 Vogue (L322) |
It's not the beam itself that causes the problems - it's the glare caused by poor/unsuitable/missmatched optics. |
In what ways exactly are the optics poor, mismatched and unsuitable ? 2012 TDV8 Vogue (L322) |
I'd never go back to old skool bulbs now. Never had anyone flash me on dipped. All good |
