Home > Maintenance & Mods (L405) > Replacement Headlight "bulbs"
Page 4 of 5 <12345>
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi Gang,
Just catching up on some of the conversations and spotted this one - Interestingly, i've been saying for some time that the headlights (both dip and main beam) on my 2016 L405 are not where near as bright as the ones on my previous L322.
They are not the LED matrix lights (sadly) but are the rest of them all the same - (ie how can I tell which bulbs i need for mine as a direct replacement/upgrade) Ash
2016 SDV8 AB
Post #682146 8th Jan 2024 3:06pm
D3s, xenon or led.. Thumbs Up
i also cranked up my beam angle just a little bit.. ... - .- -.
Post #682149 8th Jan 2024 3:24pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
knwatkins wrote:
I'm trialling these at the moment...
https://www.aliexpress.com/item/1005005227734418.html
Arrived in a 5 days. Pretty impressed so far.
How are they after 3-4 months? I would prefer bulbs without fans, but that may not be possible. Dan. šŸ‡ØšŸ‡¦ 2013 L405 5.0 SCV8
Post #682152 8th Jan 2024 3:33pm
ttrw2
Similar to lots on this thread, I was disappointed to find 2014 L405 headlights worse than my outgoing 2010 L322 headlights. In particular, the light on the kerb/verge was quite poor.
Ahead of discovering this thread Iā€™d done some fiddling and found a new pair of D3S xenon bulbs, correctly fitted* brought the L405 headlights up to L322 standards.
The bulbs that came out were original, so nigh on ten years old and the replacements were nothing fancy - Neolux from Amazon.
*I found the LHS headlight bulb not fully seated in the housing - the L405ā€™s ā€˜spiders legsā€™ and clamp are not as positive in placing the bulb as the much simpler L322 clamps. Pushing the bulb in and clamping fully made a big improvement to LHS light output alone.
Post #682160 8th Jan 2024 4:20pm
comports
So I bit the bullet...
Eagerly await the arrival of the OPL5 D3S LED Headlight Bulbs (as per the link from Pheonix on the 1st page of this thread)
Will update once they are fitted - I'm guessing its only a 15 min job to replce the bulbs. Ash
2016 SDV8 AB
Post #682310 10th Jan 2024 9:27am
it would be 15 mins if you didnt have to remove the air ducts on each side to get to the back of the headlight unit.. .. ... - .- -.
Post #682314 10th Jan 2024 10:25am
Gremlin500
Gremlin500 wrote:
I just fitted these:
AliExpress:ļæ”29.25 58ļ¼… Off | D1S D3S LED innovative 3 copper tube canbus 140W 6500K white D2S D4S D3S D1R D2R D3R D4R12V LED TO HID LED headlight
https://a.aliexpress.com/_EQrLH3p
UPDATE:
These are still going strong 2-1/2 months later, and only Ā£14.00 each now, the light output is phenomenal compared with the original or even upgraded Osram HIDs.
IMHO, much of the stuff on eBay is just the same as AE, plus the Resellers mark-up.
Iā€™m going to order another pair now as spares.
I think all the high-output LEDs will have fans, due to the heat output, is that right?
The headlight enclosures donā€™t seem to get unduly warm, even after a long night drive, having said that plenty of ā€œwind chillā€ out there currently! Laughing ā€œIf it ainā€™t broke, donā€™t fix itā€ -whereā€™s the fun in that?
Post #682315 10th Jan 2024 10:26am
Gremlin500
Rolling Eyes
Something else to bash us FFRR owners with:
https://news.sky.com/story/headlight-glare...n-13045326
Censored ā€œIf it ainā€™t broke, donā€™t fix itā€ -whereā€™s the fun in that?
Post #682333 10th Jan 2024 2:28pm
knwatkins
Absolutely fine. A much greater improvement over stock and a nice, crisp white light. They are now only Ā£13.29 a pair too Thumbs Up Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #682370 10th Jan 2024 9:45pm
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
I'm old enough to remember exactly the same complaints when tungsten bulbs first gave way to halogen and for some reason there was nothing in the news when HID's came into use. It's baloney and it's headlight adjustment that is generally the problem, added to the clowns who have forgotten the car they are driving right now doesn't have auto-dipping. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #682388 11th Jan 2024 9:09am
Bora20
Thank you. I ordered a pair. Dan. šŸ‡ØšŸ‡¦ 2013 L405 5.0 SCV8
Post #682437 11th Jan 2024 3:21pm
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
Gremlin500 wrote:
Rolling Eyes
Censored
It's not aimed specifically at any vehicles - just LED Glare from anything.
I have yet to speak to any driver that drives at night that does not find LED headlamps a problem.
Whoever (individual or organisation) "signed them off" without further development to elliminate glare needs burning at the stake.
Post #682489 12th Jan 2024 11:00am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
It's a real pain, I have artificial lenses after cataract surgery and the "starburst" effect for me from LED lights at night is a bit of a problem.
Still looking for some kind of night driving glasses that cover that but so far nothing I've tried is any good.
I also see rainbows in my periferal vision from street lights, but not sure if that's the spliff I had or just me.
Rolling with laughter
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #682490 12th Jan 2024 11:11am
Bora20
The problem with retrofit LED lights is people installing them into reflector headlights. I added LED bulbs to my momā€™s Toyota Sienna van that comes with projector halogen headlights. The cutoff is crisp, they are aimed correctly, and the light output is phenomenal.
I will not replace my wifeā€™s Subaru HID bulbs as they are in HID reflector headlights and will cause glare. The pickups with retrofits or OEM LEDs are an issue when a leveling kit (front 1.5ā€ lift) is installed AND the headlight aiming is not adjusted.
Cataracts would be a pain no matter what. Thats tough. Dan. šŸ‡ØšŸ‡¦ 2013 L405 5.0 SCV8
Post #682512 12th Jan 2024 2:38pm
fisha
Just fitted a set of the aliexpress bulbs. First impressions are they feel brighter than the outgoing ones which are likely about 9 years old now. Definitely a green tint to the light compared to the warmer hid.
So on the point about glare ā€¦ side by side above, LED on the right. Black tape on the door was to keep alignment, photo adjusted to bring out the beam patterns and not trying to show brightness. You can see the led shares the same reflective shape/ patterns so I canā€™t see that with projector lights there is any more of less glare. The light seems to be going to the same places. I do see they are a bit more diffuse. this may actually make for a more even spread of light compared to sharper differences in brightness with the hid pattern.
Only thing Iā€™ve noticed so far is in the very far right of the beam there is an upwards kick to the light. On the road, this rise ends up starting at the far edge of the beam on the opposite verge and not into the on coming traffic. V8 or else ...
Post #682903 16th Jan 2024 5:37pm
Page 4 of 5 <12345>
