Home > Maintenance & Mods (L405) > Replacement Headlight "bulbs"
Page 2 of 5 <12345>
so my bad ,i was incorrect.
out this morning to check the headlights..
on my 2016MY with no adaptive or cornering lights the dip and main both beam from the one projector...no light comes out of the inner oval .. ... - .- -.
Post #674976 6th Oct 2023 7:38am
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
Thanks Stan, no light comes from my inner oval either. As you said previously, the daylight light led’s just go around the edge. Just ordered some LED bulbs. 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #674978 6th Oct 2023 7:47am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Hi all there is a YouTube video from Powerful uk, on replacing the lens cover which goes into detail of what's inside the headlight. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #674980 6th Oct 2023 8:33am
GrandadRob
Phoenix, I just fitted the LED bulbs from your earlier Amazon link. When I have had a night drive, I’ll report back. Quite an easy job, just a bit of a faff getting the air boxes off. Tried to take the first one off whole, doesn’t work, split them, then it’s ok. Thanks all Bow down 2013 SDV8 4.4 SE Luxor.
Post #675167 9th Oct 2023 6:07pm
Phoenix
Sorry about that, I did mine whilst I was changing the air filters and airbox screws so I didn't think to mention it!
Post #675172 9th Oct 2023 6:24pm
mjdronfield
I’m looking at fitting the LED bulbs that Phoenix linked to, but to my L322. Are folk still happy with them?
How does the hi and low beam work with the shutter as the Amazon blurb seems to indicate that the LED bulb has a mode for each…. Not sure is L405 has the same shutter arrangement…..
https://www.amazon.co.uk/OPL5-D3S-Headligh...3&th=1
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #675282 11th Oct 2023 10:18am
GraemeS
Australia
I fitted the same style of 50W LED D3S globes to my MY12 L322 with no thought whatsoever of refitting the HID globes.
Post #675283 11th Oct 2023 10:42am
i bought these much cheaper bulbs Mark and they still work ok,
https://www.ebay.co.uk/itm/195398486970
the leds bulbs work in the same way as the xenon ones...the L322 and the L405 use shutters that are closed for dip and open up for main.. ... - .- -.
Post #675285 11th Oct 2023 10:47am
mjdronfield
Ah cool. Thanks for your feedback Gents. Good enough for me….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #675287 11th Oct 2023 11:10am
GrandadRob
Further to me fitting the Amazon bulbs suggested by Phoenix.
was out last night, the difference is stunning. I have just to work ok the height, I wound them full down to get the idea, too low so up a bit to get it right. The technical method defeats me sadly. 2013 SDV8 4.4 SE Luxor.
Post #675326 11th Oct 2023 4:46pm
this is from the WM, hope it makes sense ,
Post #675328 11th Oct 2023 5:19pm
Right, that's it, I've finally pulled the trigger and ordered some Cool
I'm in France right now and Amazon.fr had a discount code & 80 euros seems just about OK.
Hopefully they work OK when driving on the right and don't dazzle others (too much)
Post #675378 12th Oct 2023 10:11am
GrandadRob
Just be careful when fitting. Lights off. Ignition off. Otherwise lots of voltage. Other than that, it’s easy. 2013 SDV8 4.4 SE Luxor.
Post #675380 12th Oct 2023 10:17am
Thanks for the advice - it's the installation of these that's been putting me off for so long. I have some free time and winter is coming, so based on the positive reviews I'm finally doing it.
Post #675423 12th Oct 2023 5:04pm
Phoenix
They're just the light source, the optics (and shutter) in the headlamp assembly determine where the light is positioned on the road.
Post #675425 12th Oct 2023 5:16pm
Page 2 of 5 <12345>
